Macdude
Hi /on/ Fidelity
DIY Replacement feet for the Pioneer PL-518 and 560
This idea came to me in a dream. Maybe it's been done before, but it works well. If your 518 or 560 (or whichever other Pioneer table had deteriorating feet) has no feet left, maybe you can go this route.
I've been around Technics 1200 series turntables enough to know that parts are pretty easily available for them. I've ordered feet before for the 1200 and wondered if there was a way to easily retrofit them onto the 518/560. Apparently it's do-able. Here's how:
You'll need to first order 4 feet for the Technics SL-1200 series turntable. Used ones would work fine. These should have a threaded bolt-like mount. It is an M6 thread (metric).
You'll also need 4 M6 "pronged tee nuts". This is basically a nut you can hammer into a hole. The trick is finding one in M6. If you're in the US, don't bother checking a hardware store. I bought a pack of 8 on eBay for $2.50, $4.50 shipped.
A drill, hammer and a 3/4" spade bit will also be required (spade bit is only needed for the 560). The 560 differs in that the base plate is larger and covers the holes the original feet screwed into. The holes on both the base plate and the plinth must be enlarged and the tee nut recessed so that the plate will fit back on correctly.
