Hey guys,
I've got a C-70 thats been running like a champ for about a year since I bought it. I absolutely love it! Unfortunately.... it's giving me some problems.
It has a weak/static output on both of the channels, it is slightly worse on the left. Now, I opened it up and look for all of the obvious things. I can't find any bad solder joints from a general look over (top and bottom of the board). I also can't find any obviously damaged or burnt components.
I am suspecting the main output relays. These are the relays that are in series with the main output jacks. The reason I am suspecting these is because if I lightly tap on these two relays with a screw driver while the amp is on, it fixes the problem. Though, not permanently. Now, I cleaned one of these relays about 4 months ago when a similar issue occured on only the left channel. I was thinking about replacing the relays. However, I can't find any of the Matsushita HB2YD-DC24V that is in it. Do you guys have tips on where to get a drop in replacement or really good steps on cleaning the ones on the board?
Thanks in advance!
Daniel
Thanks in advance!
Daniel
