Hi guys first of all Happy Thanksgiving!
I tried my battery operated gun & a bbq grill ignitor & compared the results between the two. I will post the results after I explain somethings.
Here's what I came up with so far. (Note: I had to cut the marker tube on the lathe so it would fit the gun hole.)
1. I removed the light & it's both wires.
2. Ran the ground point from the trace of the board to the metal backstrap I made as a ground point. The gun actually worked without the ground point but just not as good.
3. I shortened the length of wire running to the pin point you aim at the record. I also tried thicker diameters of metal to see if it would work better then a pin point. All thickness did work but just not as good as a pin point.
4. I made a small tube to go over the pin point. It seems like this tube makes the gun less effective when it's on.
At this point I took some packing peanuts & rubbed one on an old album that's warped. I held the gun at various lengths away (1/4" to 6") with both the grill ignitor & my battery operated gun. They both work very much the same way moving the peanut slightly sometimes & at others knocking it completely off. I must say both worked much better closer to the record & peanut.
After 4 hours of trying different lengths away, different amounts of rubs, different patterns of movement & with & without the tube covering the pin point my battery operated gun seemed to do much better then the grill ignitor & it seemed to do much better without the tube on.
I did notice at times the peanut would not release but if I lightly pinged the album it would fall off & not stick afterwards. I also notice around the edge the album there was still static because the peanut stuck. After using the gun it would not.
After Thanksgiving I will post a video showing it in action. Any advise to make it better would be appericated!
Here's a couple questions for you Zerostat owners.
1. When squeezing your trigger do you get that snap like on a grill ignitor?
2. When releasing the trigger do you get another snap?
3. Does anyone have any pictures of the inside of a Zerostat?
I'm guessing here that on a grill ignitor that snap which is caused by a spring releasing a little metal piece inside the button when pushed in is what is needed to slam against the point that connects to the peizo inside to create a spark. Without that violent action the spark would not be created. Right? If that's the case then wouldn't the Zerostat gun need a equal reaction when releasing the trigger? Or is the trigger made to work smoothly with some type of spring setup? Because once the grill ignitor snaps it doesn't matter how slow you release it the metal piece is already back.
Below is my final pictures so far.
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
