Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Speakers
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 12-05-2010, 07:40 PM
Fast996's Avatar
Fast996 Fast996 is offline
Mod that Vintage Gear
Upgrading the JBL L200
I have aquired a pair of JBL L200's and with my current pair that I purchased in the early 70's I want to use them in a 4 channel system. I have a large room downstairs and for under a 1000 invested I just couldn't see going with anything else for the money.
What is the mods that can be done to these to improve the bass,midrange and high frequency sound. I wouldn't consider changing the woofers out but would be interested in adding a high freq. driver and upgrading the crossovers.
I did a quick search but didn't find what I was looking for. If there is a thread please post it.
Thanks
__________________
Crown CX844's,CX824,Ampex MR70 1/2" 2T,Ampex AG440C-B,354,350-2 custom, Ampex MR70 1/4" 2T;VAC 140's&70/70,MacMR78,Accuphase C200,P300,Studer C37 60hz 1/4" 2T
  #2
Old 12-05-2010, 08:59 PM
barredowl's Avatar
barredowl barredowl is offline
Before and after Science
Might be an interesting ewave with a modern wave guide, do a search here.
__________________
Carver C-1, S. Crafts. PA50001, Tan. Sy. 800, M & K VX-7
Ken. C1, Ad. 545 II, Rega P1, San. TU-S9, M-Aud.410, MacBook, JBL 4313b, Yam. YST-SW100
  #3
Old 12-05-2010, 09:27 PM
Fast996's Avatar
Quote:
Thanks,
Is that the thread that is 817 freakin pages?? How bout the super micro condensed version, say 3 paragraphs...maybe.
__________________
  #4
Old 12-05-2010, 09:45 PM
Zilch's Avatar
Zilch Zilch is offline
Curve Junkie
Quote:
It's all summarized with links in the first post of the thread here:
http://www.audiokarma.org/forums/sho...d.php?t=150939
Literally hundreds have been built by others worldwide; that thread is now pushing inexorably toward a million views.
The precursors to EconoWave were L200s built by both AKer Jackgiff and myself, fully documented on Lansing Heritage in the Q&D thread.
Here's the index:
http://www.audioheritage.org/vbullet...pired-Contents
Do that with today's standard E-Wave driver and waveguide using the high-efficiency variant of the crossover, and you'll be good to go with a cool $400 or more extra in your pocket after reselling the original drivers, horns, crossovers and acoustic lenses....
__________________
"More data ... less wank ...
In relentless pursuit of truth, enlightenment, and the AudioKarma way...."
November 22, 1942 ~ February 4, 2011 R.I.P.
Audiokarma.org Member of the Year 2010
  #5
Old 12-05-2010, 09:52 PM
Tom Brennan's Avatar
Tom Brennan Tom Brennan is offline
AK Member
Quote:
How about a compensation network for the original compression drivers and horns? Then he'd still have L-200s but improved. Perhaps.
Audiokarma
  #6
Old 12-05-2010, 10:04 PM
Zilch's Avatar
Curve Junkie
Been there, done that, Tom. The original exponential horns beam the high frequencies so badly that the vertical beamwidth virtually goes negative. See Fig. 4 here:
http://www.audioheritage.org/vbullet...peaker-Systems
The only other way to "fix" them is convert to 3-way, the standard approach being to add JBL slot tweeters with N4333 crossovers, a $500 - $1000 upgrade, and unless you also change out the horns to the longer exponentials, that's still not going to get quasi-L300, which further requires swapping out the woofers with 2235H to achieve the extended bass of those later designs.
L200B boosted the HF with comp, and failed for these reasons, even with Greg Timbers (as I recall) doing it. 2-way just didn't happen until 4430, and nobody's looked back since....
Footnote: See the Altec 511 directivity and beamwidth plots in that tech note, as well, Fig. 3. BOTH the horizontal and verticals beam, and that's why 4430 with its true constant-directivity horn by Keele beat out Model 19, the first product to actually incorporate HF comp as a 2-way VHF extension strategy some 3-4 years earlier.
__________________
  #7
Old 12-05-2010, 10:10 PM
4343's Avatar
4343 4343 is offline
AK Member
Thanks,
As one that has used the very same components for many years:
While I love the sound of the "Foghorn" and L91 Acoustic Lens, it has limitations, mostly the lack of "Flat to 20K" that some people like. (I find the rolloff very nice, but I've learned to also like the sizzle that's missing...)
Also, the directionality is lacking. If you take the Acoustic Lens off, you will hear the horn beaming all the highs right down the middle, the lens tries to spread the highs sideways, but only does a mediocre job of it. You must still aim them at your ears to get a flat response. Much to the side and the highs get muffled.
The modern Constant Directivity waveguides solve this problem, for a lot less change. Now I'm not one to say you should cut up decent L-200's*, and just adding a supertweeter can bring them into the '80's, soundwise, but it has been done before, and the results are pretty amazing, not that the stock or tweeter modified L200 can't sound pretty amazing in it's own right (take a pair outside and feed them some watts, you have a downright amazing backyard barbecue/block party system! Reworking the crossovers to eliminate any tiny iron core inductors (and recapping) can make them sing even more.
My 3 paragraphs.
*Others have been pounded pretty hard for suggesting that in the past, maybe not here, but near here!
__________________
Mike Scott in SJ, CA Drive 'em to the XMAX!
  #8
Old 12-05-2010, 10:19 PM
4343's Avatar
AK Member
Cool
L200B boosted the HF with comp, and failed for these reasons....
I did not know that. That's my one reservation about the 4430, trying to EQ the top end flat pushes the diaphragm into breakup, which looks like extended high end, but sounds like hash. Does anyone make 1.75" Be diaphragms?
__________________
  #9
Old 12-05-2010, 10:23 PM
Zilch's Avatar
Curve Junkie
Smith, Keele, and Eargle rolled off the 4430 VHF at 16 kHz; the reason is apparent in the distortion plots.
1.75" Be diaphragms are in the works at TruExtent.
__________________
  #10
Old 12-05-2010, 11:05 PM
Fast996's Avatar
Here's the index:
Thanks Zilch, I will read through it.
How about the complaints on the bottom end,boomy and such. Can a redone crossover help this?
__________________
Audiokarma
  #11
Old 12-05-2010, 11:10 PM
Fast996's Avatar
My 3 paragraphs.
4343
Can the stock tweeter be modified? Or is that accomplished by adding a super tweeter.
__________________
  #12
Old 12-05-2010, 11:19 PM
Zilch's Avatar
Curve Junkie
Not everyone agrees with respect to the boomy bass; you're just going to have to listen for yourself, once you've done the HF upgrade.
Jack and I both switched to 2235H.
The original woofers have high resale value, I suspect because DIYers are using them in bass horns, maybe....
__________________
  #13
Old 12-05-2010, 11:30 PM
AK Member
I used a pair in fairly big sealed boxes; actually they were L-220 boxes left over after I sold off the guts. Anyway they sounded pretty good but then again I wanted them to; know what I mean?
  #14
Old 12-05-2010, 11:41 PM
4343's Avatar
AK Member
Cool
4343
The stock tweeter is more of a midrange, really. It's spec'ed to 20KHz, no qualifier, which means it's probably at least 10dB down up there. And eq'ing it up to flat only adds distortion, lots of it. (Caused by the fairly large dome "breaking up", where the metal actually bends due to standing waves building up in it.) They have a real nice rolloff that makes vocals and acoustic instruments sound very natural. Tube amps can make them sound really nice.
They are what they are, a fairly nice sounding, efficient tweeter horn/lens that sells for a nice price. Assuming the original Aluminum diaphragms are in good shape.
I still remember the first time I heard them, I immediately set out the sell my Altec 511 horns with 808-8A drivers and acquire them. Never looked back.
Since the Ewave bug bit, I've been using them less, and less, and less. Now with Be diaphragms, and a CD horn...
__________________
  #15
Old 12-06-2010, 12:17 PM
toddalin toddalin is offline
AK Member
Best mods to make to the L200 include:
Punch out the back to put the longer horn in (shown here with the LE175 driver):
BTW, at the lower end of their range, the LE175 is smoother and extends lower than the LE85 and almost lets you get away with the shorter horn.
Redo the crossovers:
Add the slot tweeter:
Cut out the base, make it taller, and put a new base on it to get the woofer further from the floor and add ~3/4 cubic foot of internal volume and put a plug in one of the two ports.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
McIntosh Cabinets
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Audio Doctor
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
