Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Infinity Loudspeakers
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 12-08-2010, 08:57 PM
nissan guy nissan guy is offline
AK Member
infinity rs3's
I was just wondering if anyone has any experience with the infinity rs3's? I havent personally heard them. So i have no idea how they sound, but i have a chance to get a set. I usually listen to rock,classic rock and alternative that being said i have no idea how the rs3's would sound with any of those types of music. Here are some pics. They look to have had the bottom driver replaced at some point, i am not sure what brand it was replaced with.
__________________
Currently using: nad 7120, Music hall mmf5, goldring 1012gx, epos es-11
  #2
Old 12-08-2010, 09:55 PM
Tedrick's Avatar
Tedrick Tedrick is offline
Infinity-phile
Yep, the lower woofer has been replaced with something non-Infinity. Unless the price is knocked down accordingly, that would be a deal-breaker for me.
Although they are quite serviceable with rock music (they work just fine by me), it has often been said that Infinity speakers of this era work best with jazz and classical. Seems like most good rock speakers are bass reflex designs (ported or passive radiator). But the only real way to know is to give them a listen.
__________________
MAIN SYSTEM
VPI Aries I - Lyra Clavis - Sutherland PH3D
Music Hall Maverick - Forte Model 2 - Forte Model 6 - Infinity RS-IIb
OFFICE
VPI Classic - Lyra Delos - Dynavector P-75
Burson Soloist - AKG K702
Nakamichi TR-3A - KEF Ref 102
  #3
Old 12-08-2010, 11:46 PM
tubed's Avatar
tubed tubed is offline
AK Member
The RSIII is a classic in that even though Infinity designers employed multiple woofers in other models, the RSIII is the only example I can think of where Infinity used a dedicated woofer, a single driver dedicated to frequencies 100Hz and below.
The RS III's sound really good and look super cool.
I substituted an 8" Infinty QE woofer for the bottom driver and got much better bass response....... I imagine if the speaker cabinet could take a 10" driver the sound would approximate the RSII's.
Good luck and enjoy!
Actually I recently discovered that not only does the RS III use a dedicated bass system but also the RSII's, much to my excitement.
Last edited by tubed; 12-16-2010 at 12:52 AM. Reason: RSII & RSIII dedicated "sub"woofer
  #4
Old 12-12-2010, 11:03 PM
AK Member
I may end up picking them up. I am not sure yet though, i am having the owner check into what type of drivers are in the bottom. I may just see if he can lower the price a bit on them, they are very cheap already though. The only thing is they are quite a drive for me.
__________________
  #5
Old 12-12-2010, 11:36 PM
tubed's Avatar
AK Member
I don't know what caliber of speaker becomes available in your neck of the woods, but the RSIII is worthy of a drive not too out of the way.
The mismatched woofer is easily attainable from EBAY as it and it's equivalents come up quite often and don't cost an arm and a leg.
They look to be in very good condition. Go for it.
Audiokarma
  #6
Old 12-15-2010, 05:55 PM
AK Member
They actually need 3 woofers to be brought back to original. Are the woofers hard to source? Are they expensive? I seem to find lots of qa,qb speakers avialable on ebay, would any of those be suitable replacements?
They are pretty cheap, but if i have to put alot of money into them i dont know if it will be worth it in terms of sound quality per dollar. Someone correct me if i am wrong.
__________________
  #7
Old 12-15-2010, 07:06 PM
StimpyWan's Avatar
StimpyWan StimpyWan is offline
AK Member
nissan guy,
While I can't say if it'd be worth it to you to restore your RS III's; I do know if I owned a pair, it would be worth it to me to keep them running. Those speakers are definitely worth the cost and effort to restore.
If you need to be cost conscious in the restoration, just find 1 replacement woofer to start, and swap out the one odd upper woofer. Since the upper and lower woofers cross over at different frequencies, it would work better to at least match the upper midbass-woofers 1st, then as funds permit, buy more woofers as they become available, and replace both lower bass woofers at the same time, to complete the process of bringing the drivers back to stock.
As to availability, that's a fairly common Infinity woofer:
http://www.infinity-classics.de/infi...ical_sheet.pdf
8" WOOFER
#902-4976
Substitute #902-5030
It's also used in the RS-4B, RS-6B, RS-7B, RS-8, and the RSe (if not more). So, look for those model drivers. I don't think the older Qa and Qb drivers would work as well. But, you never know.
Also, there's a current auction (not mine), for a set of 4 RS-4B woofers, that are compatible with your RS III's.
Heck, Infinity even still lists a current version of that 8" woofer as still being available from Infinity Parts & Accessories:
http://www.harmanaudio.com/search_br...F&MarketId=HOM
So, give it a try. And if you change your mind, let me know. Maybe I'll take 'em off your hands!
Good Luck!
__________________
Pioneer DV-563A, Sonographe SG-3
NAD 116, HLLY DAC-01A, Indeed G2 Headamp
Hafler DH500, 2 Amber ST-70's, NAD 3155/2155
Meyer Sound HD-1, AR-90, Monsoon FPF-1000 & FPF-600, Infinity RSE & Infinitesimal 0.3
Pioneer Elite VSX-03TXH & NHT 5.1
  #8
Old 12-15-2010, 07:20 PM
AK Member
Thanks for the info. I havent actually bought them yet, they are very reasonably priced and i am going through the pros and cons of them right now. I just dont know it these would be a set that i would like alot. Also would a ss kenwood kr7400 power them or would i have to run them with something higher powered than 65wpc? I know the power rating is 20-200watts, but will i be under powering them?
__________________
  #9
Old 12-15-2010, 09:08 PM
tubed's Avatar
AK Member
There are four of what you need on EBAY with your name on 'em.
  #10
Old 12-15-2010, 11:14 PM
Tedrick's Avatar
Infinity-phile
Before buying these, you need to measure that clear poly-cone woofer. It looks like a 10" woofer, which would mean that the hole for that woofer has probably been enlarged and would no longer accept the stock 8" driver.
__________________
MAIN SYSTEM
OFFICE
Audiokarma
  #11
Old 12-15-2010, 11:31 PM
AK Member
I am pretty sure the silver trim ring/edge just makes them look bigger. I could be wrong, they are suposed to have 2 8" woofers from what i have read.
__________________
  #12
Old 12-16-2010, 12:38 AM
Tedrick's Avatar
Infinity-phile
You may be correct, but I'd still measure the distance between the screw holes and compare them to the screws mounting the clear poly woofer.
And yes, the RS-III uses 8" woofers.
__________________
MAIN SYSTEM
OFFICE
  #13
Old 12-16-2010, 05:31 AM
Lastplace's Avatar
Lastplace Lastplace is offline
AK Member
I had a pair loaned to me for a while and grew to love them, great imaging. Both lower woofers had to be replaced in this set also. We used these http://www.reconingspeakers.com/prod...ofer-902-7298/ They were slightly deeper and had to be installed as the upper woofer.
If they were local they would be mine.
__________________
Henry Kloss (1912-2002), father of the "east coast sound"
  #14
Old 12-22-2010, 03:13 AM
renli3d renli3d is offline
AK Member
I have the RS-III's that were restored by Sir Byrd. The speakers sound awesome. They're very energetic and push out each note with a purpose if you know what I mean. Bass is surprisingly very, very good. I have pairs of Celestion Ditton 662's and Ditton 66 Mark II's as well which have woofers that go down to 18 hz and the Infinity's actually have a more distinct, faster, more powerful bass response though the Celestion theoretically go lower.
  #15
Old 12-22-2010, 03:47 PM
AK Member
Cool i may have to pick them up if he still has them after xmas. I was looking for as much info on them as i could find. I really didnt want to take a long trip to pick up something i wouldnt want to keep. The more positive things i hear about them the more it makes me want to get them.
The person is the original owner and he said he replaced the drivers that had bad surrounds quite a while ago and the new ones just bolted in place. he couldnt remember the brand of the replacements, but i can find originals pretty easily it seems. So he didnt modify the cabinets at all.
__________________
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
