Levinson HQD
hatrack71
distracted by everything
So I have paid almost all of my Levinson purchase off through trades and cash. These were custom made by the previous owner. They should be even more fantastic when I get the other one today and set them up. I'm really stoked. Here is the pic of one I got yesterday. They are too big to take two in the vehicle I had. I still need to pay off the Decca ribbons which go in the center and the DB systems crossover which is extremely flexible.
That's very cool! Is the cabinet with the stacked drivers in the picture the Hartley subwoofers?
Best Regards,
TerryO
That's very cool! Is the cabinet with rhe stacked drivers in the picture the Hartley subwoofers?
Best Regards,
TerryO
Hi Terry. Actually I am going to use my RBH sub and outboard power amplifier/crossover. What you are seeing on the left are my JBL Apollos which I am substituting the LE-14As for the D-140fs. I was not all that impressed with the Hartleys the previous owner had and for that reason am going with the RBH. What he had were 2 crudely built transmission line subs using 10" Hartleys. If it had been an 18" or 24" Hartley, they would be mine. The 10" Hartleys are nowhere near the performance and sound of the 18 or 24" drivers. The cabs he built were nowhere near the quality craftmanship he put into the stacked panels. He definitely knew what he was doing. He also has 3 303 power amplifiers I might try to pick up as well as they run the ESLs safely without any arcing.
Here's a couple more pics- I just got back with the other one- wooohooo
That sounds like it will be an impressive system. If you should want stupendous Bass output at some point in the future, you may want to try a pair of Maelstrom 18's or 21 inch woofers.
Here's a link to the Maelstrom 18:
http://www.diycable.com/main/product_info.php?cPath=24&products_id=681
I'd certainly go with your present Sub first, as there has been a great deal of improvement in Subwoofer design since the HDQ system was sold and it may be enough, or you may want to add a relatively inexpensive "Distributed Bass" system to create a SOTA system that will complement your present subwoofer.
In any event, that's going to be some system when you're done!
:thmbsp::music::banana:
Best Regards,
TerryO
very very nice,
i have the decca london tweeters, eventually hoping to get some esl 57s and stack them
Those HQD's are very nice. The frames the seller made look gorgeous. Single ESL 57's have midrange to die for but not enough volume. A stacked pair solves the volume problem. The Decca ribbons add needed high end air and sparkle. A decent sub or (better) subs is almost mandatory.
I heard a pair of HQD's many years ago.They soured me on cones and most other speakers. That listening experience caused me to sell my then Maggy MG-3's for some ESL's. ESL's have been all I use since then.
hatrack71:
SOTA = State Of The Art. The HQD system at one time was considered SOTA.
hatrack71:
Joe, by my ear, I would say that it is definitely still state of the art. Better than anything I've ever heard. I do have a new appreciation for my Acoustats as well. ESL's are so sweet.
More pics with one set up in the previous owners home. He did better on the frames than the stock Levinsons in my opinion. There is a pic of the crossover I will be getting ( it also has a separate power supply). I am considering the 3 303s he has too. You can just make out the Hartleys behind the stand. Should I go for them even though they are only 10"?
looks like your planning on using the decca super tweeters, not the horn loaded decca londons? i thought the londons were the original spec units
very very nice,
Your 1/5 of the way there. Keep being patient- it is well worth the effort. I can also draw up plans off of these stands if anyone would like them.
the 57s are fairly common units, decca londons not and i am undecided on a bass unit, if anything i feel there has been real advancement in terms of bass units in the past twenty years while the mids and treble of the deccas/57s remain cutting edge.
i would like info on the crossover :D
I'm not sure about that- I've seen both in HQD systems. I don't have the ribbons as I have to pay for them and the crossover yet. A little at a time for me due to my financial sitting. I've been working on this deal for 8 months and it has definitely had it's frustrating moments but all is downhill from here. I don't think there is much difference other than the horn. I could always make one out of wood and contrast it against the oak baffle- like a dark walnut to match the front grills- that would look and sound good. That should also give the tweeter much more volume. I have gravitated to wood horns after building a set of 1200Hz Smiths.
DB systems crossover. Still a working company. These were custom made for this system incorporating Butterworth filters and a separate power supply. 3 way crossover with attenuation for all 3 bands. It is extremely sweet. Should I try to get the 10" Hartleys?
Are these what you have? There is a pair on eBay right now.
hatrack71:
Joe, I will say the ESLs have spoiled me for cones too. One cone design still sounds good to me though- Dahlquist DQ-10s. They are sweet too.
those are the decca kellys, they were earlier designs but so popular they ran concurrently to the londons, i attached a pic of the londons.
regards the harleys, personally i would only purchase them with a view on selling for a profit, cant help but feel better bass units are out there, subwoofers have come a LONG way in the past 30-40 years.
I may be wrong here but aren't all of the Decca ribbon drivers mountable to horns? Couldn't I build a lovely set of walnut tweeter horns for the ones I am getting? Looks like it has the same 4 mounting points.:scratch2: Also, on the Hartleys, is it true that they can play under water? Just a weird tidbit the previous owner was telling me. Isn't there a better box that I can build for the Hartleys? They are currently in TL boxes and extremely tall behind the panels as you can see in the pic of the one set up. I've seen subs mounted in boxes that fit between the stands and just come up to the panel. Check these out- in the second system. http://www.marklev.com/systems/index.html
