rabbit
Well-Known Member
http://cgi.ebay.com.au/50-pcs-Ceramic-Axial-Capacitors-3pF-0-25pF-200V-/290336720857
Just thought I'd let people know that I just bought some of these caps off ebay to replace the notorious unreliable black flag compensation caps in Sansui Amplifiers such as the AU-919 and AU-X1 etc
Most of the ceramic NPO caps sold these days are only 100 Volt which is cutting it a bit to fine for an AU-919 with +/- 55Volt rails.
These caps on ebay are good quality AVX brand with CO(G) dielectric so have a good temperature coefficient and tolerance which is perfect for this type of application.
For other parts of the amp such as the gain and RIAA preamp stages which use 6 pf caps you just need to parallel two together.
