DoomSlayer
Member
The first issue is that when i turned the FM on today it was fine for about 5 min, then just went off. Power was still on, the radio just went silent. Then about 10 seconds later, it clicked like it does when you first power up and everything was fine. It did that off and on for about 10 min. So i thought i would try the cd player and played fine for about an hour and nothing happened. I have it on FM again and it has been for about 30 min and it hasn't dont it since! Anyone have any ideas?
Another issue is that the right channel(or right side on the unit) is about twice as hot as the left! Its not smokin hot but there is a differance! The left is almost cold and the right is hot. I was thinkin that it may just be too close to the entertainment center so i moved it away about 5 inches. Still could be what it is, but i thought i would ask. Im going to move it on top of the entertainment center see if it helps.
Thanks,
Ian
Thanks,
Ian
