Marantz 1250 "dual core" filter capacitor replacement
KrZ8
Greetings,
The main filter capacitor of my Marantz 1250 failed a couple years ago and I finally replaced it. Since the 1250 is using the dreaded "dual core" capacitor type, there was some construction work involved. Here is how I did it.
Since digikey doesn't stock 14000uf+ capacitors slim enough to fit in the available space, I chose four 12000uf Panasonic TUP.
1 - The original capacitor is held with a bracket and 3 screws, so I first cut a base plate. (Images 1 & 2)
2 - I then cut and prepared a curcuit board plate on which the new capacitors will be mounted. (Image 3)
3 - both plates were then aligned and drilled together to allow the installation of plactic risers. (Images 4 & 5)
4 - I soldered the capacitors to the curcuit board, and added the wires (Image 6)
5 - I installed everything into the Marantz. Images 7 & 8 (see next post)
It is a tight fit, but this great amp is finally back in the living room! :music:
I hope it helps someone,
Alex
Images
Here are images 7 & 8.
Nice job. While you are (were) on it, perhaps a couple of 0.1uF film type bypass caps across each rail and ground plane on the new soldered board might increase the improvements.
Wow, well thought out and delivered solution, congrats! If you didn't know the difference, the new caps look like they were the stock deal.
Reading through the posts I see part locations labeled like q1 or q2 and stuff like that. I'm new to this and would like to know where is the diagram that shows me what is what? Thanks in advance!
Images
Hi sir,
That is a while ago that you recapped the PS capacitors of the Marantz 1250. My question is how did you connect the polarity of the capacitors and why did you choose four 12000uF values and not just two 12000 uF capacitors?
Hi sir,
The member hasn’t been seen since 2017, seven years ago.
