quid_non@hot
Member
Got a vintage 1060 off da' bay recently. It worked, lots of hiss, had seen some use and was very dirty! After taking the case off and looking around, it was clear that someone had done some repair work on this in the past - no evidence of a recap, but someone had replaced the power switch, volume control pot and several other items. Headphone jack was in three pieces - parts all over the place. Power "on" lamp was burnt out.
Started disassembly to clean boards prior to recap. Used 91% isopropanol in a spray bottle, tooth brush and compressed air to dry. Got alot of yellow, "tacky" goo off the boards. Ordered all caps from Digikey - replaced them w/ equal uf/voltage as possible with Elna Silmic IIs. Total cost for all caps was ~$50 (including the three big cans). Marked cap "polarity" on board w/ pen to make sure I could line up proper polarity for install of new cap
Cleaned all boards and chasis:
Here's the "before" of the P800 power supply board:
Now the "after recap"
Recapped P900 Phono amp board:
So far this is going slow, but steady. I am noticing several "errors" in the 1060 service manual and the actual board - this was noted by others before. Will summarize these (several wrong caps listed in the service manual) and follow up.
Will post more as it develops - thanks for looking.
Please offer any advice/ tips as the progress develops!
