Hot Rod Oscilloscope
RocknRoll
Hot Rod Oscilloscope :D
by Dennis L. Feucht
With apologies to the '60s hit tune, "Hot Rod Lincoln"
You've heard the story of the bandwidth race,
Where 'scopes and counters were setting the pace;
Well that story is true, I'm here to say;
I was using a 545A.
It's got a graticule, all lit up,
That front-panel claptrap makes it look tough.
It's got plug-ins, uses 'em all;
It's got good risetime, and also fall.
With a dual-trace display at reasonable cost,
And forty-eleven knobs, you can really get lost;
It's got a dual-delayed timebase, but I ain't scared,
The trace is sharp; the probes are fair.
Pulled out a new project late one night,
The test equipment was burning bright,
I started driving a wideband amp,
To see which stage I needed to damp.
When all of a sudden in the blink of an eye,
A series of waveforms passed me by,
And I said, "Wow, that's a marvel to me!"
Pretty soon a square-wave was all I could see.
Now the boss was ribbing me for being behind,
So I thought I'd make the probes unwind,
Took the volts per div knob, and man alive!
I turned it up to a setting of 5.
Powered the wideband amp again,
And drove it with a function gen,
Set the amplitude knob to three or four,
The levels were hitting the ceiling and floor.
Now the transient response made no sense,
The scope display looked like a picket fence.
I slowed it down and was glad to know,
That it wouldn't alias like a DSO.
I tweaked the circuit here and there,
Replaced a cap and transistor pair;
Got the speed I needed with room to go;
Manufacturing would be glad to know.
Smoke was coming from out of the load
When I set the trigger to hf mode;
The power bandwidth was looking right;
Nearly approaching the speed of light.
The task was finished, the specs first-rate,
The customers called, said the amp worked great;
I got a promotion, moved out of L.A.,
And I credit success to that '45A!
Whoo baby!
A song about oscilloscopes! We have finally reached Nerdvana!
A round of pocket protectors for all!
Fetch the skinny clip-on bow ties!
Now, where are my horn-rimmed glasses? Oh yeah, over by the K&E slide rule...
attachment.php
