Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Speakers
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 03-01-2011, 06:30 PM
Mingo's Avatar
Mingo Mingo is offline
AK Member
Anyone have info on RCF SCD 6000 ?
There is a pair of RCF SCD 6000 speakers/monitors for sale locally. I did not find much info about them via Google. Anyone have experience or information about 'em?
File Type: jpg 3k23m13pb5Y25T15S1b3144d396dfe0131f44[1].jpg (5.6 KB, 50 views)
  #2
Old 03-01-2011, 08:53 PM
rifftrax's Avatar
rifftrax rifftrax is offline
mix-meister
VERY expensive high-end monitor. If you can score them for a couple hundred in working condition you're doing quite well. They are built like literal tanks and may be the best speaker you ever own (depending...)
If you're talking about the set in S. Austin...for that price you should really go. Resale value isn't great due to obscurity but if you aren't looking to flip these may be the last speakers you ever purchase.
  #3
Old 03-01-2011, 09:35 PM
Mingo's Avatar
AK Member
I sent an inquiry to the seller earlier today, but have not received a response. I was trying to get an idea of their size and what is needed to drive them, among other things. It sounds like I may need to arrange an audition.
  #4
Old 03-01-2011, 10:05 PM
Turborusty's Avatar
Turborusty Turborusty is offline
2nd hand junkie
Quote:
Is this the Mingo I think it is?
Is this where you've run off to?
Turborusty
  #5
Old 03-01-2011, 11:10 PM
rifftrax's Avatar
mix-meister
Yes, definitely go (if they're still available) and bring the beefiest amp you can muster.
They are studio mid-fields so they will take gobs of power. Maybe bring a back brace or moving dollies or something.
Audiokarma
  #6
Old 03-01-2011, 11:30 PM
Mingo's Avatar
AK Member
Turborusty
You may have this Mingo confused with another one...I have been in the Austin area for many years, perhaps too many considering the changes that this town is seeing.
  #7
Old 03-01-2011, 11:52 PM
Turborusty's Avatar
2nd hand junkie
Must be a different Mingo. The one I knew was from an old car club we used to frequent.....he's from San Antonio.
Carry on then
Turborusty
  #8
Old 03-04-2011, 02:34 PM
Mingo's Avatar
AK Member
Well, I went and checked them out. And decided not to buy them. The tweeter on one of the speakers was not working; not sure if it was a blown tweeter or a bad capacitor. The crossover looked fairly complicated, but I did not investigate too closely. The working speaker sounded great. I was tempted but, in the end, I don't need another project.
  #9
Old 04-25-2011, 04:56 PM
KJR-Eng-LLC KJR-Eng-LLC is offline
AK Member
I have a pair of RCF SCD 6000's and info
The monitors like some fairly strong power and big cable, I run mine with two amps dropped into mono for about 525W per unit. I run the power in mono because the amp's damping factor is higher in mono and controls the woofer better providing for better accuracy. the mid-high components can be rotated to provide either a vertical or horizontal positioning of the monitor. I have a jpeg scan of the manual if anyone needs the info within.
The imaging is really good, as is the combined source point from the top end components, smooth & easy to listen to. The monitors will be for sale as of May 15, 2011
  #10
Old 12-01-2012, 10:34 AM
charlieperso charlieperso is offline
AK Member
I have a pair of them.
These boxes have been tested on Stereoplay/Italy showing ruler flat anechoic room response from 45 to 18 Khz. Attenuation is 12 db/oct under 45 hz, which means lot of output at 20 hz (think of walls/floor and even ceiling) in a real room.
MIL is well above 500 watts at lowest frequencies. If I remember well, the magnetic unit for woofer as the one for the mid and tweeter pounds over 5 kg.
The woofer is a pro unit, of which RCF is rewardered. The domes too come from their experience in horn drivers.
You can use even good small amps (mines ar now connected to a 35 w Linn Majik), but these are really professional Near Field Monitors, and you can drive them with a lot of power.
Voicese are really clear, bass instruments very dynamic indeed. Highs could be a little harsh if the amp is not smooth.
Only, be careful about interactions with the environment, because they could deliver really deeb and powerful low frequencies.
Audiokarma
  #11
Old 12-17-2012, 04:25 PM
G-M_London G-M_London is offline
AK Member
Hello everyone! New guy here; I'v been reading these forums for several years and decided to join.
I have used a pair of the SCD-6000s for over twelve years. They sound and look as good as the day I bought them. Several pieces of the gear running into them has changed during that time – from Crown to Emotiva etc, and they all sounded fine through the RCFs. By the way, RCF designed the cabinet; the internals are made by Eastern Acoustic Works – a company located in Framingham Ma.
  #12
Old 12-17-2012, 04:36 PM
budgetaudio6's Avatar
budgetaudio6 budgetaudio6 is offline
AK Member
welcome G-M Some pics would be in order. Perhaps on a new thread.
__________________
Go on go in!
http://www.flickr.com/photos/budgetaudio6/
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Tone Arm Audio
Tuner Heaven
Classic Sound Repair
Take Five Audio
Acoustic Sciences Corporation
Audience AV
Cabledyne
BD Enterprise
BOI Audio Works
Howard Products
Amplifiedparts
Audio Art Cable
RSL Speakers
Siliconray
Salk Sound
Vinyl Magic Record Cleaner
Musical Paradise
Audio Salon
Urban Antigue Radio
Grant Fidelity
Many Moons Audio
Yesterday's Audio
McIntosh Cabinets
Simply Speakers
The Tube Store
DeWick Repairs
AudioClassics
Parts Connexion
Audio Doctor
Vintage Electronics Repair
MCM Electronics
Politicalchat.org
Herbies Audio Lab
Antique Radio Classifieds
Sound Stage Direct
Videokarma.org
FM DX Antenna
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
©Copyright 2002-2012 AudioKarma.org, All rights reserved.
