After much research and redesign I have finally completed my RCM.
ala Keith Monks/Loricraft
The parts are mostly re-purposed:
The platter is powered by a motor from a bread machine
it is running at approx. 80 rpm it is coupled to the
platter with some rubber wheels from a HP printer.
A pioneer pl-300 was used for the platter and the basis for the suction arm.
The suction arm is magnetically coupled and power is from a 1rpm motor.
The vacuum pump is an oil filled refrigeration mechanics service tool, it is
a slight overkill but was free!
The brush is for a Loricraft and the fluid is delivered via a 12v univ. windshield washer pump.
There is a small amount of moisture left on the record after cleaning,
which is due to the suction arm moving a little too quickly. It takes about
40-45 seconds. I thank all of those that helpfully provided information and
inspiration along the way. It sure has been a learning experience and very
challenging:headscrat at times.
