Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Tube Audio
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 03-22-2011, 03:26 PM
stromberg721 stromberg721 is offline
AK Member
Question 1962 stromber-carlson console sterio- help
I have a large wood 1962 stromberg-carlson AM/FM radio with record player console model #. I am looking for more information on the rarity. AM/FM radio works but the record player, unfortunalty does not; I believe due to a bad switch. I have searched countless hours online for information and have not even found a picture of one. Is this a rare item?
please help
here is a picture i took of mine
  #2
Old 03-22-2011, 03:38 PM
mibag6 mibag6 is offline
AK Member
Questions of value usually get bumped to Dollars and Sense forum. You'll probably get more info in the tube forum. Might want to edit out the value questions. It probably has a nice little push pull 6V6 stereo amp, can't tell you much else.
  #3
Old 03-22-2011, 03:43 PM
AK Member
thanks
  #4
Old 03-22-2011, 03:56 PM
Stromberg48's Avatar
Stromberg48 Stromberg48 is offline
"Classic Chinese audio"
looks like a record changer, Is that a record changer or a manual tt? My guess is this is a 63 or later model. a front pic would be nice.
__________________
1948 Stromberg Carlson Chinese Classic TV-12-M5M (TV-Radio-Phonograph), SC 1220, RF-475 alnico, AR-420 amp, RV-520 reverb kit, JBL c38 lowboys
  #5
Old 03-22-2011, 04:28 PM
spaceman's Avatar
spaceman spaceman is offline
Registered Lunatic
That looks a bit different from either one I've messed with, but looks more like the one that had a SE 7408 amp, the ASR-110. My Penthouse is much longer, with a section on each side of the lid. If you can take off the back & grab pics of the amp & drivers, we can offer more help.
__________________
I don't know why I thought I should have some kind of divine right to the blues. - - - Pete Townshend
Audiokarma
  #6
Old 03-22-2011, 05:40 PM
century tek's Avatar
century tek century tek is offline
AK Member
That is the same as the one I picked up a few years back. Sinse you don't have a pic of the amp, its either the ASR-110 or ASR-120. The ASR-110 is single ended 7408's & the ASR-120 is push/pull 7408's. Both have the 7199 drivers and 6CA4 rectifier. I believe Tom Bavis has both schematics. I got my ASR-120 schematic from him.
  #7
Old 03-22-2011, 05:45 PM
AK Member
Quote:
Its a record changer. You can tell by the long spindle that's able to hold a stack. A manual TT usually does not have the long spindle or arm to hold the records, and/or the "REJ" option. That particular TT has the speed control as the outer knob, and off-on-rej as the inner round control.
  #8
Old 03-22-2011, 06:53 PM
larryderouin's Avatar
larryderouin larryderouin is offline
AK Member
The changer is a Voice of Music changer. IIRC it's a 12xx series unit. Lift it out and look for the model and serial #'s as outlined on the V-O-M site. They also have parts for the changer too.
Larry
__________________
FISHER Cons.; 51 WR-11, 59 510/610 (both chas,) and 560, 63 Exec VIII(800-C), 64 E-49, 65 E490,'65 F590.
FISHER Comp; Tube:TA-600, 400, 800-C,101-R, MPX-100, 80-T, 50-F. Solid State: 160-T, 250-TX, 400-T, 550-T, 500-TX(2), 700-T, TX-100
S.S. PIONEER, Sansui, Scott
  #9
Old 03-31-2011, 06:23 PM
AK Member
more pics
model number on the record player is
MRS 4058
148-000
107
67012148
HERE ARE SOME MORE PICS
  #10
Old 03-31-2011, 06:59 PM
AK Member
your info from the changer doesn't match up with what VOM is saying.
it's quite possible that S-C put their own info on it also.
Here's the link you want to check on the changer http://www.thevoiceofmusic.com/do_i_have_vm.html
Did it not come with legs??? It looks like the type that should have at least 7"or 8" legs.
__________________
Audiokarma
  #11
Old 03-31-2011, 07:10 PM
Tinkerbelle's Avatar
Tinkerbelle Tinkerbelle is offline
Everything in Moderation
Cool pics. As others have said, that looks to be the single-ended model ASR-110. I think Tom Bavis has schematics plus the Sams for the console on his website: http://www.audiophool.cjb.net/MadeInRoch.html (scroll down)
__________________
To give anything less than the best is to sacrifice the gift - Steve Prefontaine
  #12
Old 03-31-2011, 11:11 PM
Thespeakerdude8's Avatar
Thespeakerdude8 Thespeakerdude8 is offline
AK Member
Quote:
Not really, pretty standard Stromberg console. Nicer in some cases than some of the Magnavox's. Its in poor shape to be worth a lot of money, but is it worth fixing? Yeah! Finish work isn't too hard, and it probably just needs a few capacitors replaced. Would I dump a couple hundred into it? No.
  #13
Old 04-01-2011, 08:51 PM
orthophonic orthophonic is offline
AK Member
The Record Changer is not VM, it is a Glaser Steers, these changers are rather unique in that the platter stops spinning before the record drops, then
starts spinning again when the arm lands on the record.
Nice looking Modern style console, would probably be an easy restore.
  #14
Old 04-01-2011, 10:14 PM
KentTeffeteller's Avatar
KentTeffeteller KentTeffeteller is offline
Gimpus Stereophilus!
I agree you have a Glaser/Steers changer installed. The overarm and general styling does not appear to be V-M of the period. It's a much better than average console in sonics and build, only Fisher, Ampex or HH Scott are rivals here. Worth some love and restoration. The Stromberg-Carlson consoles are superb sounding and the better of the herd.
  #15
Old 04-01-2011, 10:27 PM
AK Member
I'll be damned. I coulda sworn it was a VOM. Learned something new today. (Boy am I in trouble......Old dogs, new tricks!)
Larry
__________________
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
AudioFriends
Capacitor World
Okki Nokki
Analog Engineering Associates
Vintage Home Audio
Organ Donor Parts
Hudson Valley Hi Fi
Wargos Electronics
Take Five Audio
Parts Connexion
Sound Stage Direct
Simply Speakers
Audience AV
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
