Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > DIY
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 03-22-2011, 03:38 PM
westend's Avatar
westend westend is offline
Audiopile
Altec MLTL with Model 19 drivers
This thread will document a large MLTL enclosure using the Altec 416-8b. The design of the cabinet was done by GM, an Altec user and installer with many years of experience in audio and a damn fine individual. The initial design considerations were discussed here on Todd White's Altec User Board. To summarize the goals: Raise the height of the woofer to accommodate my listening space and to improve upon the low position of the original Altec Model 19 alignment.
I will be using the Altec 811 horn and a Heil AMT1 tweeter on the top of the enclosure. The cabinet dimensions are 52 3/4" H x 30" W x 21" D, volume is 16 1/2 ft.^3.
Preliminary sketch using Google sketchup (without true scale, I'm not that good with the program, yet):
Note: At one time I bought six sheets of Birch plywood from my local lumber superstore. These turned out to be full of voids and the interior plies were probably not the same species. They were returned and 13 ply, 19mm Baltic Birch in 5' x5' sheets were purchased from my local hardwoods supplier.
I am about to start cutting and am sorting sheets. I'm going in.....
  #2
Old 03-22-2011, 03:44 PM
Russellc's Avatar
Russellc Russellc is offline
AK Member
Ah, finally the Altec project cometh!
russellc
__________________
Scillia/Merrill modded AR The Turntable w/Magnepan Unitrac, SAE 1000LT, Shure V15Vxmr. AVA Super Pass III, DIY Pass B-1, DIY Pass F-5, DIY P-P 6550, JBL 6230. Indignias, Econowave: JBL 4507w/2235H, QSC152 & B&C DE 250, Altec A-7, Aria 5. MR67, FM3, Mit. DA-F10, Rotel 971
  #3
Old 03-22-2011, 03:46 PM
shawnra's Avatar
shawnra shawnra is offline
AK Member
good on ya for getting the real deal, the Baltic Birch. It pretty amazing stuff most of it comes from Russia. In Canada all most all of it is imported through Thomes Canada and they have a great detailed explanation of how this stuff is made on their website. Pretty interesting read. They also specialize in importing Aircraft plywood and I've often wondered about using it for a set of enclosures. Too expensive though. Here's a link to the importer
http://www.thomescanada.com/
Those sheets are pretty heavy so don't strain yourself Eh!
  #4
Old 03-22-2011, 04:07 PM
ejfud's Avatar
ejfud ejfud is online now
Audio Pinhead
Nice Lance. I'm excited for you to get this going.
Please don't bring back those ugly old fake Model 19 cabinets you took from me a while ago or I'll have to sick my wife on you.
Any thoughts on mounting the horn to a baffle to help dampen them?
__________________
Gary
i jam econo.
  #5
Old 03-22-2011, 04:28 PM
doucanoe's Avatar
doucanoe doucanoe is offline
Registered Audio Abuser
Looks like your off to a good start Lance!
RC
__________________
When it's all said and done,.. who gives a rats azz.
Audiokarma
  #6
Old 03-22-2011, 05:03 PM
djnagle's Avatar
djnagle djnagle is offline
AK Member
Looking forward to seeing this develop Lance. What are you using for the 811 driver? What crossover?
__________________
My "Art" website
http://home.comcast.net/~djnagle/site/
  #7
Old 03-22-2011, 07:10 PM
westend's Avatar
Audiopile
Those cabinets went to another local AK'er that has more time and patience then myself. Please, don't let the wife at me!
Initial plans are an adjustable sled w/ mounting baffle. I found that I was not hearing any of the infamous ringing when the front flange of the horn is securely bolted to wood.
Quote:
RC
Thanks Ron, at least it's a start.
Quote:
I have been using 802-8g's with the original light aluminum 'phragms. I am already thinking about different hornage. I've been using active crossovers and don't know why I would change that, they just work so well.
F*&k, I need a sheet crane, you're right they're heavy. The only way to deal with that is to start cutting!
These sheets would probably be a grade "B" according to the grading scale from Thomes. I do have access to some marine grade plywood but 1/2" dimension sheets 4' x 6', IIRC, are $110. They are made with phenoiic resin and are glassed on one surface. Heavy, straight, and expensive.
  #8
Old 03-22-2011, 07:24 PM
diamondsouled's Avatar
diamondsouled diamondsouled is offline
Chronic ;^)
Great project!!! I love the great Heils. How are the diaphragms in yours? I have 5 pairs and when I hooked up a 4 a side array I found out that they were not all outputting the same SPL. What frequency are you crossing the Heils over at? I guess if it's high enough you wouldn't have to worry about any notching.
This makes me wonder if I should sub a Heil into my Valencias some time to hear what they sound like in there. I'm using 2404 Cheeks right now.
BTW what type of corner joint are you planning on using?
Cheers
Lar
__________________
Altec Valencias ESS AMT1A Monitors Revox B795 TT Uher Royal Deluxe RTR VAS Cit Sound Mono Blocks HK Cit I II III Pilot 232 Audible Illusions Modulus 3 ARC SP3
  #9
Old 03-22-2011, 08:21 PM
westend's Avatar
Audiopile
Cheers
Lar
Hey, Lar. The Heil pair I have seem very well matched, I've never measured them (don't have the gear yet) but they always seemed balanced. I plan to cross them at about 9Khz or so.
I had pondered what kind of joinery I was going to use on these and expedience and practicality won the day. They will be butt-jointed with a ledger (gusset) in each corner. I have a lot of faith in Titebond III, I guess. Everything I've built using that adhesive is still together, including my sliding tool boxes in the truck which get a lot of abuse. I plan to embellish the exterior of the cabs when I have them all together. I have ideas, oh yeah.
  #10
Old 03-22-2011, 08:44 PM
westend's Avatar
Audiopile
cutting tutorial
Thought I would show this since I read about some guys having difficulty with cutting panels and they shy away from speaker builds or use Home Depot's panel cutter and the results aren't always good.
Firstly, I have a good table saw, fence, and out feed tables, more than enough gear to cut these 5' x5" panels. I choose to cut them, however, using my trusty Makita 7 1/4" circular saw and a straight edge. Some folks will tell you that you can't get a good quality of cut with a circular saw and the pictures, here, should dispel that. I will be using the table saw when I have the panels cut to some smaller dimensions for good repeatability.
As said, Makita 7 1/4" 5007NB (been dropped and thrown around for many years and keeps ticking), Freud Diablo 7 1/4" 48 tooth finishing blade with a very small kerf (1/16" or so), E Emerson 8' clamping straightedge, metal rule.
After assessing the squareness of the panel, I mark my cut line, measure the distance of the saw blade tooth to the edge of the saw table (in this case it is close to 5 1/16" in.). The clamping straightedge is positioned back from the cut line the aforementioned dimension (5 1/16"). Adjust the saw until the blade will cut 1/16" deeper than the sheet. I use a piece of MDF under the sheet I'm cutting and it is a sacrificial table that is steady and doesn't impede the blade. Position the saw at the straightedge and push it down the sheet with the edge of the circular saw table against the straightedge. At about mid cut, I look to see if the cut is trying to close and, if so, throw a little wedge in there to keep the cut open. Take a look at the pictures and you'll see the results.
This is an easy way to get accurate cuts in sheet goods and saves some laborious lifting and setup with the table saw.
Audiokarma
  #11
Old 03-22-2011, 09:09 PM
ejfud's Avatar
Audio Pinhead
Only way to break down a sheet of plywood in my eyes. A circular saw and a good straight edge. Beatuiful cut line. That Frued blade is great. I've used this technique for many years. The only thing that's changed is I was given an amazing Festool circular saw/guide rail setup that makes quick work of this job.
Keep the educational stuff coming Lance. I always learn from your techniques.
__________________
Gary
i jam econo.
  #12
Old 03-22-2011, 09:15 PM
jaymanaa's Avatar
jaymanaa jaymanaa is offline
Badge #301
Hey Gary, try a red diablo thin kerf wet lumber blade. They are like a lazer beam. I bought one for my skillsaw and now have them on the table and mitre saws. Frueds are good too though.
OOPS, just noticed the Diablo in the post above. Didn't know they were made by Frued.
__________________
Encumbered by idjuts, we pressed on.
  #13
Old 03-22-2011, 09:25 PM
ejfud's Avatar
Audio Pinhead
I need a new blade for my table saw. I'll be heading to the home store this weekend. Thanks for the tip Jay.
__________________
Gary
i jam econo.
  #14
Old 03-22-2011, 09:30 PM
specialidiot's Avatar
specialidiot specialidiot is offline
Huge Member
Great project Lance, I'll be watching!
Would you mind pointing me to your BB source? I have a little project in the works......
__________________
Office Rig: Project RM5.1SE/Sumiko Blackbird, MacMini,Sony XDRF1HD,Grant Fidelity Tube DAC-11, Jaymanaa/Eico HF-81, RayW Bobbins
Vinyl Rig: Yamaha PF-800/Dyna 10x5, modded Jolida JD9a, modded Bottlehead Foreplay III, Redboy SET45, 4Pi
  #15
Old 03-22-2011, 10:12 PM
Doc Zinger's Avatar
Doc Zinger Doc Zinger is offline
AK Member
Looks like another great project, if I keep reading these DIY threads I might get the urge to shitcan my speakers and amps just to have the fun of building something else again.
Saw something about horn damping, if your horns aren't exposed you might consider using Plasti Clay. I used on my 24" alum horns and on my Electro Voice tweeters and they are dead when you tap them, don't look so hot though.
I also thought about using a rubber strip product that's used for waterproofing around windows/doors after install before siding. Home Depot has it, about 6" wide made by Grace, sticky on one side( sticks like hell after putting down) thought it might be good to line interior cabinet surfaces(about 1/8" thick) and cut down panel resonances seems like it would cost alot less than some of the producs sold for that purpose.
Hope the panel wrestling match cut down went ok, once you get to the table saw the real fun begins.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Tone Arm Audio
Tuner Heaven
Classic Sound Repair
Take Five Audio
Acoustic Sciences Corporation
Audience AV
Cabledyne
BD Enterprise
BOI Audio Works
Howard Products
Amplifiedparts
Audio Art Cable
RSL Speakers
Siliconray
Salk Sound
Vinyl Magic Record Cleaner
Musical Paradise
Audio Salon
Urban Antigue Radio
Grant Fidelity
Many Moons Audio
Yesterday's Audio
McIntosh Cabinets
Simply Speakers
The Tube Store
DeWick Repairs
AudioClassics
Parts Connexion
Audio Doctor
Vintage Electronics Repair
MCM Electronics
Politicalchat.org
Herbies Audio Lab
Antique Radio Classifieds
Sound Stage Direct
Videokarma.org
FM DX Antenna
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
©Copyright 2002-2012 AudioKarma.org, All rights reserved.
