Hello all,
The function of the rubber cushion A "boot" is twofold. Most importantly it provides a positively centered compliant seat for the spring, and second, it provides a thin rubber sleeve that fits snugly over the spring to help damp spring coil resonances.
I hate to say it, but most of the Audio Karma advice I have seen (including the advice posted here in this thread) demonstrates a lack of understanding of this part. Remember, when it comes to these turntables (and the Yamaha PX series, and the Sony PS-X SLT series), I do not proclaim my opinions from the arm-chair, my advice comes from actually working on these repeatedly and carefully studying their idiosyncrasies and special needs.<<
>>>First let's look at the advice for using an O-ring for the spring seat. Like I have already stated here "most importantly it provides a positively centered compliant seat for the spring". A typical round cross-section O-ring from the hardware store will not provide adequate lateral positive centering. The O-ring will tend to slip between the coils of the suspension spring and now the plinth looses its necessary centering. Of course, there is always the possibility that an O-ring will work in your particular situation (unlike me, you might have been born under a lucky star), but this is not the correct, thorough, and proper way to effect a repair that you can be confident and proud of.
Second is the less important issue of spring coil damping. Energy of all frequencies is doing its level best to ingress into your turntable from the feet and any other surface it can (nature abhors a vacuum). Frequencies higher than the fundamental resonance of the suspension spring/plinth mass combination will try to set the spring coil into a harmonic resonance condition. In addition, the primary fundamental resonance of the suspension will need to be tamed with some damping as well. This is what the sleeve portion of the Rubber cushion A does.
So the bottom line is:
1- Don't use a round or X cross-section spring seat. Use a square cross-section seat of suitable durometer and material.
2- If you must use a sleeve, use a sensible, stable, and compliant material/device that will not impede the free movement of the spring such as a finger from a thin rubber glove or even a condom. Again you can use a spring sleeve, but I don't think it is necessary.
Finally, what I would like to convey here is how important it is for audio forum posters to have their facts straight and to make the effort to thoroughly and properly understand the physics of whatever they are volunteering advice on.
There are countless cases where an innocent reader of a given thread implements forum advice only to break something or compromise the performance of whatever device he is involved with. Of course there are also many cases where forum advice was very helpful and my guess is the good advice is more prevalent than the bad. Let's strive to improve this ratio as much as possible.
Best wishes, Professor Bizzt
