TerrySmith
Here's an AA-32 I've had for several years, it was an ebay purchase. It appears to be a low mileage unit, all cloth insulation is still soft and flexible and has all it's original Mullard tubes! Now the bad part, it looks like it was stored in a damp shed or basement for many years and became home for generations of mice, the aluminum chassis was heavily corroded, I painted it hammertone gold. I still need to repaint the cover.
I stripped it and used the chassis for a preamp project and then moved the preamp to another chassis except the phono stage.
Now I've returned it to an AA-32 with a few changes:
Power amp section is stock except added a buss bar ground and seperate cathode resistors and caps.
Phono stage is from the RCA tube manual, leftover from previous project.
IEC power connector.
New caps stuffed in old can.
Individual parts for tone controls, I've found the stock PEC's to be noisy.
Simplified linestage- line inputs go straight to volume control instead of being attenuated and going through half the phono stage.
DC for the preamp tubes.
This turned out to be a really sweet sounding amp!
