G-22000 - protection circuit time delay problem & recapping adventure
Oh, I love this vintage stuff, it sounds great and never fails to keep me on my toes.
Normally when powering up my G22k it takes about 10 seconds before the red protection LED goes out and the green goes on.
But the other day the delay was basically non-existent and the speakers made a semi-nasty sound on power up.
After that - all was sweetness as usual.
In my research I found an earlier thread that address this issue and the recommendation was to clean the auxiliary power switch that is on the rear panel (on the amp section adjacent to the fan outlet). I tried cycling it a few dozen times to clean off any crap (at least until I could get in there with some DeOxit) but that didn't change the no-delay behavior.
I've been turning off the speaker switches prior to power on when using it in this state as a temporary safety measure.
I've already recapped the front half of this unit so I figured it's time to recapped the back half - the power supply, protection and amp PCBs. I placed the order with Mouser for the various higher voltage caps required.
But behold - this evening I turned it on and it went through the normal 10 second delay. Now, I'm nowhere religious enough to think that this has fixed itself so I'll be going forward with the recapping and servicing exercise.
Where previously I suspected either the aforementioned power switch or the transistor (SCR?) that drives the relay now I'm thinking that the relay itself was mechanically locked up. It's possible that the contacts were arced together from the power being rapidly cycled and now it's broken loose again.
Any thoughts?
JimB
Any thoughts?
JimB
