#766
Oh, cool, thank you. This thread is getting a little unwieldy to sift through... Unfortunately I'm adding to that by posting this.
#767
This sure has changed from the original build with 6 OpA and a projected build price of over $100!!!
Bless you, (All whom are involved) Ron Quote:
#768
Ok, so I built a really unconventional CNC preamp, and it might be biting me in the ass. Instead of running both channels through both chips, I split them up so each one only handles one channel. In addition, it is all point to point circuitry using the component leads. Lastly, for the ground, I put in a solid sheet of copper about an inch below the main board, and any components that go to ground, I dropped the leads through the board and soldered them right to the copper sheet.
It sounds good, but it is a little noisy. Anyone have any ideas why? At high volumes there is kind of a rustling noise. Maybe I should have stuck to a PCB.
#769
The chips are going to have far better channel separation than any cart that will be run thru them. That dead side may be part of the problem.
__________________
Goodness comes from getting the basics right, glory is to be found in tending to the details. |
#770
What do you mean, dead side? Both sides of the chip are in use, it's just that one side is used for the channel's first stage, and the other side handles the second stage.
Anyway, I swapped chips side to side, and it looks like I just have a noisy op-amp. I noticed that the noise was only coming from the left side, but after swapping, it is only coming from the right. Wouldn't have been able to do that with the conventional layout. ![]() I knew I should've gotten an extra, but I didn't want to shell out the $6.
| Audiokarma |
#771
I have noticed some op amps do have a rustling sound and some don't, you would think they would have better quality control.
__________________
Benz Micro Ace / Pro-Ject Perspective II, Speed Box II, HypnoToad AD797 MC PhonoStage, Nakamichi 482Z, Yamaha C4, Yamaha M2, Polk SDA 1C. |
#772
I'm not going to guarantee that it wasn't damaged by handling. After all, technically we should all have grounding straps on when handling these. I believe that ICs can be damaged by far less static discharge than you can actually feel. Anyway, now that it actually works, I don't feel so embarrassed to post pictures of this monstrosity.
![]() Yes, it's weird looking, but that's part of the fun. If you're going to build something yourself, why have it look like it came out of a factory? The switch is going to get moved a little bit. I plan on cutting a piece of lexan to cover the front of the box, and the switch will be mounted onto that. ![]() ![]()
#773
OK, got it. Bad new chips are kinda unusual.
__________________
#774
I agree completely. These things are usually not bad out of the box. I didn't think it was the chip, but I decided to swap chips side to side, and sure enough, it changed from the left to the right.
#775
CNC and SSP boards
Hi all,
I have just received PCBs for CNC and SSP.Please find pics below: Uploaded with ImageShack.us Uploaded with ImageShack.usI am going to PM everyone who have shown interest for boards. Regards, Sachin
__________________
Micro Seiki MB-14st, Ortofon Super OM 10 DIY CNC MM Phonostage, Technics SlD-303, DIY Pass B1 clone with LDR volume control Technics Su-8022 Not a nice man to know |
| Audiokarma |
#776
Fantastic, three cheers for Sachin, great work!
__________________
Benz Micro Ace / Pro-Ject Perspective II, Speed Box II, HypnoToad AD797 MC PhonoStage, Nakamichi 482Z, Yamaha C4, Yamaha M2, Polk SDA 1C. Last edited by HypnoToad; 12-19-2011 at 09:56 AM. |
#777
Quote:
I sent it back for repair and put in a grounding plate that got touched before any of my equipment. Now in winter a humidifier runs as long as I am not listening. Sachin, PP sent, your receipt confirmation received. Thanks from all of us.
__________________
"Remember, you are the only one who needs to be happy with the sound of your system." Grainger Morrison |
#778
+1. These look great!
__________________
Upstairs: Pioneer SX-780, Technics SL-1300 w/AT 440MLa, Nakamichi CR-1A, KLH 23 Downstairs: Denon POA-1500, Soundcraftsmen DX4000, CNC Phono Pre, Technics SL-1360 w/Shure M75 & Jico SAS, Sony CDP-770, Denon DRM-600, Klipsch KG4 |
#779
Hi all,
I will try to ship max boards tomorrow,remaining will be sent day after. Regards, Sachin
__________________
#780
Thanks sachu888. I look forward to getting my boards soon.
Thanks all for your hard efforts.
__________________
Philips GA312/Stanton 681EEE/Jico D6800EEE-S Shibata> Yamaha DVD-S2700 CD.SACD.DVD>Mon THX i100> Yamaha RX-797>Mon MSERIES MCX-2S> Klipsch RF-7 2ch |
| Audiokarma |
| Thread Tools | |
| Display Modes | |
