Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Tube Audio
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 05-29-2011, 06:17 AM
zekk zekk is offline
AK Member
UTC CG-300 Pinouts??
Hi Folks,
Can anyone please help me to figure out the variable primary connections?
Pri: 0v, 105v, 115v, 220v, & 230v.
Sec: 625v - 515v - 0v -515v -625v.
Data sheets does not show pin connection!
v
Uploaded with ImageShack.us
  #2
Old 05-29-2011, 07:01 AM
PakProtector's Avatar
PakProtector PakProtector is offline
AK member
hey-Hey!!!,
I suspect the secondary is in two separate pieces, and likely the primary as well. One bit of primary will be 0-105-115 and the other 0-115 so the entire combination of input voltages can be configured( ex. the 220 is created with the 0-115 connected in series with 0-105 of the first bit I think ). Now the secondary is likely created by putting the two bits in series. Now if that is the case you can make a 615-110-0-110-615 secondary by reversing the polarity. Perhaps useful for creating a negative rail bor either bias or a cathode follower...
See what is connected to what with an Ohm meter, the primaries will be low compared to the secondary and there *MAY* be a separate tap for grounding the core.
cheers,
Douglas
__________________
1990 D250, NV5600, Luk 05-101, 16cm housing, TST Kit KDP tab, Powr-Lok'd 3.07, HX35...IC soon
She wasn't built to travel at the speed a rumour flies
  #3
Old 05-29-2011, 07:44 PM
AK Member
Thanks, Douglas!
Using a variac to check out the pins, it's confirmed that the sec. taps are 7 to 11 at 625-515-0-515-625 respectively.
Applying 105v to pin #1/#2, #4/#5, pins #7-9-11 reads 625-0-625v.
The same 105v to pin #1/#3, #4/#6, pins #7-9-11 reads 515-0-515v.
So, I've two pairs of primarys.
If I series the primary for a 230v supply, will I be getting a doubled voltage across #7 and #11, eg: 1250-0-1250v?
Regards, Zekk.
  #4
Old 05-29-2011, 08:11 PM
AK Member
... just answered my own question!
By connecting pin#3 and #4 together and applying 230vac to pins #1 and #6, I got 625-515-0-515-625v on pin #7 to #11 respectively.
Thanks all for watching.
Zekk
  #5
Old 05-30-2011, 06:31 AM
AK member
Quote:
Originally Posted by zekk View Post
Thanks, Douglas!
Regards, Zekk.
But you can arrange a 220 connection and apply 120V to it and deliver a little more than half that voltage. It will cut the volts/turn and make it radiate less which may be useful in a lower voltage design a typical linestage would use.
cheers,
Douglas
__________________
Audiokarma
  #6
Old 05-30-2011, 07:30 AM
AK Member
Thanks again, Douglas!
I'm building a SEUL TT22 with EL802 as driver.
So, needs high voltage !
Will post pics and schematic when ready.
Regards, Zekk.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Meistertech Solutions
Capacitor World
AudioFriends
Analog Engineering Associates
Vintage Home Audio
Okki Nokki
Hudson Valley Hi Fi
Wargos Electronics
Organ Donor Parts
Parts Connexion
Sound Stage Direct
Take Five Audio
Audience AV
Howard Products
Simply Speakers
The Tube Store
FM DX Antenna
AudioClassics
Many Moons Audio
Audio Doctor
RSL Speakers
Yesterday's Audio
DeWick Repairs
BOI Audio Works
Politicalchat.org
MCM Electronics
Amplifiedparts
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
