Audiokarma.org
Audiokarma Featured Sponsor
Audiokarma will be offline March 7th and 8th
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > General Audio Discussion
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 06-13-2011, 08:17 PM
70WR 70WR is offline
AK Member
What happens running 4 ohm amp connects to 8 ohm speakers?
What happens - short/long term?
I just found out that on one of my amps, the 4 ohm speaker connects (banana plugs) I had feeding 8 ohm speakers - been this way less than 2 weeks.
I found how to do it, both 4 into 8 and 8 into 4, but I don't want to know how to do it - just what happens when its done.
How I did it - I was running my tube amp into 4 ohm Maggie's, then over a week ago I pulled the banana plugs from the Maggie's (MG-I) and just plugged them into 8 ohm speakers, not thinking the other end of the wires were fed from the tube amp 4 ohm speaker connects instead of the 8 ohm speaker connects.
So to add to to my wondering, what if it was the other way around, amp 8 ohm fed to 4 ohm speakers.
  #2
Old 06-13-2011, 08:21 PM
icenine's Avatar
icenine icenine is offline
AK Member
No problem running 8 ohms on a 4 ohm tap....you just do not want to do the reverse i.e. run a 4 ohm speaker on an 8 ohm tap....
__________________
Sherwood RX-5502 Altec Lansing Santana II
Yamaha RX-397, BA-A70
NAD 7155 Snell Type III Series E,
Vector Research VRX-7100, B&W 600i
Maggie 175cc KEF 104/2
Adcom GFA 535 Music Angel Pre
Lets All Just Pray On It Right Now-Dr John
  #3
Old 06-13-2011, 08:53 PM
AK Member
^ Whew! I didn't know of harm to the speakers and/or amp. For over a week, I ran it like this daily from 2 to 8+ hours. I didn't push the amp hard so I figured maybe I'll be alright.
So if amp at 4 ohms to 8 ohm speakers is okay - why not leave the speakers wires connected to the 4 ohm connects on the amp all the time - then when I swap speakers between 4 ohm and 8 ohm - nah, scratch that - I learned a lesson and hope to always make it a point on checking this whenever switching speakers/amps etc.
I figured running amp (8 ohm) to speakers (4 ohm) is worse than what I had done. Impedance mismatch would be worse.
Thanks
  #4
Old 06-13-2011, 09:03 PM
icenine's Avatar
AK Member
Best bet is too know what load your amp can run.....read the manual. And be careful running four speakers (A+B outputs) at same time.....playing four 8 ohm speakers creates a 4 ohm load to the amp. Playing four 16 ohm speakers at the same time would make an 8 ohm load, which would be safer for most amps but there are not a lot of 16 ohm speakers out there. I know it gets confusing.
__________________
  #5
Old 06-13-2011, 09:16 PM
shelly_d's Avatar
shelly_d shelly_d is offline
Not An Audiophool
4 ohm output into 8 ohm speakers = less power output and perhaps less distortion. This can be a good thing if you end up not being shy on power, that is not pushing the amp all the way into clipping.
Reversing the mismatch and you could get excessive heat build up in the amp's output and may increase distortion, neither is a good thing.
Shelly_D
__________________
Real planes have propellers
Oxygen free copper suffocates the sound!
Audiokarma
  #6
Old 06-13-2011, 11:11 PM
donberry donberry is offline
AK Member
actually, many will recommend trying it out on both and see if there is a difference in sound and use the one you prefer. For tube amps anyway.
__________________
ML SL3 - "While some people may prefer a speaker that demands less from them, these speakers are designed for those who demand nothing less than the best from their speakers." Stereophile Review 1997
  #7
Old 06-13-2011, 11:31 PM
MelodyMaster's Avatar
MelodyMaster MelodyMaster is offline
78s galore.
Quote:
I run 8 ohm speakers on the 4 ohm tap anyway because I never approach full output and it does sound a bit sweeter that way, smoother bass and highs.
  #8
Old 06-14-2011, 12:45 AM
AK Member
I didn't know there were recommendations for this - and here I nearly had a stroke the moment I saw it, a panic shut down - for no legit reason I guess other then I thought at the moment "what am I doing to my amp!" - all for nothing
Thanks again all - maybe I'll do a comparison, I actually didn't notice it but wasn't doing it looking for a change.
  #9
Old 06-14-2011, 06:20 AM
gushtone gushtone is offline
AK Member
On a related note, I run my old Marshall head at 8 ohms into a 16 ohm 4x12 cab and I always preferred the sound to the 16=>16. Let's me push it a bit harder and sounds warmer.
Peace...
  #10
Old 06-14-2011, 12:57 PM
mhedges's Avatar
mhedges mhedges is offline
AK Member
You will lose some potential power by running 8 ohm speakers on a 4 ohm tap but other than that nothing will be hurt.
Audiokarma
  #11
Old 06-17-2011, 02:57 PM
BADBOB BADBOB is offline
AK Member
Hello . Newbie here so please forgive me for not knowing the rules yet.
This is a new thread about bi-amping .
I have a pair of infinity kappa 8.1 . I have a pair of mcintosh mc2500 amps. How do i hook these up and what do i need to hook these up ?
Any info would be appreciated .
Thanks
  #12
Old 06-17-2011, 06:25 PM
positron positron is offline
AK Member
Shelly_D
Nice points Shelly. To add a little more, running 8 ohm speakers on 4 ohm amp output will reduce peak plate currents. This is helpful when running class AB and B as plate dissipation is reduced. However, as Shelly mentions, output power is usually reduced a little as well. Damping factor is increased with such a setup compared to 8 ohm speakers on 8 ohm tap.
As Shelly also points out, reverse mismatch will cause excessive peak plate current, increasing plate dissipation, which is not good for the output tubes.
Damping factor is also reduced.
Cheers.
__________________
Positron
  #13
Old 02-05-2013, 09:57 AM
rucyrius rucyrius is offline
AK Member
Parallel
If the two 8 ohm speakers are wired in parallel and tapped into 4 ohm on the amp isn't that cutting the speakers to 4 ohm and it's all running at 4 ohms?
Also what happens if you have two sets of 8 ohm speakers running from a 4 ohm tap running at the same time ... I have a fisher 500c set on 4 ohms.. To a speaker switcher .. Most of the speakers are 8 ohm. ( one set in living room are 4 ohm super sensitive(95)) there are 4 sets of speakers in all ... I never run them all at the same time .. But am I asking for trouble if I have two sets on at a time... And what if I run one set of the 8 ohm speakers at the same time as the 4 ohm set ... They sound ok when I do it but I'm worried I'll blow up the vintage amp... Thoughts?
Thanks
John
  #14
Old 02-05-2013, 11:40 AM
shelly_d's Avatar
Not An Audiophool
Thanks
John
2 sets of 8 ohm speakers in parallel are 4 ohms to the amp. Period. Treat them the same as a 4 ohm set of speakers.
4 Ohm speakers in parallel with 8 ohm speakers makes the amp see 2.6 ohms. Place such a pair on any 2 ohm tap you may have. If you don't have a tap that goes down to 2 ohms, you should not run them in parallel. In my opinion it is just too low for the amp and could cause heat related issues in the long run, even if not causing issues in the short run.
Shelly_D
__________________
  #15
Old 02-05-2013, 12:38 PM
AK Member
Shelly_D
Then if I run the 4 Ohm speakers along with the other two sets of 8 ohm speakers .. What does that do to the amp?
Otherwise I should make sure the 4 ohm speakers are only run by themselves. Ie: without other 8 ohm speakers switched on?
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Hudson Valley Hi Fi
Okki Nokki
Organ Donor Parts
Capacitor World
Parts Connexion
Vintage Home Audio
Take Five Audio
Wargos Electronics
Audience AV
Sonneteer
Simply Speakers
Sound Stage Direct
Howard Products
AudioClassics
FM DX Antenna
The Tube Store
Many Moons Audio
Musical Paradise
Yesterday's Audio
McIntosh Cabinets
DeWick Repairs
BOI Audio Works
Politicalchat.org
Amplifiedparts
Audio Doctor
RSL Speakers
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
ęCopyright 2002-2014 AudioKarma.org, All rights reserved.
