dnpainting
The last RCM I built works pretty well with using a motor from a Pioneer PL-L1000 turntable. It does, however have its faults. 1) The platter spins too fast, IMO, for record cleaning. 2) It only spins in one direction. 3) It was built into a console cabinet and is too long and too low, I hate bending.
The new one I am going to be building will have a reversible motor, already purchased a 120V reversible) with a gearbox that I purchased separately to slow the spin down to 12 RPM. I also have a Technics bearing and platter from a, beyond repair, SL-D3 that I had purchased for a few bucks a while back. So far, I have removed the gear from the bearing housing of the Technics and cut down a sleeve to fit over the motors gearbox shaft onto the Technics bearing and drilled holes into the sleeve, tapped threads and installed set screws. The reason I decided to do it this way was I could not find a gear that had a 25.4 pitch like the Technics.
I hope Big Bill doesn't mind, but I was going to steal the idea of 12V water pumps from automotive windshield washers.
The new unit will stand taller and take up less space and hopefully live up to the high quality builds I see hear at AK.
I will hopefully be adding a twist, just trying to work out minor things to get that part to work.
Will post pics as I build.
EDIT* BTW-Motor has 43Lb's-in of torque. Added Photo of Motor.
Waiting on 2 (12vdc) washer pumps to arrive from fleabay so I can get started on the wood cuts.
Thank you
David
Thank you
David
