Know about a Kenwood KR-77 receiver?
CharlieBee
I picked up a Kenwood KR-77 receiver at my favorite source, the neighborhood garbage. Just sitting on a can waiting to be rescued. I can not find out anything about it. It says total wattage 90 but I doubt the amp puts that out. Anybody know of its power and other specs?
By the way, it has a problem with one weak channel (surprise, surprise but you would think people would only throw out good, working junk, shame, shame). The left channel is only about 1/6 power. It has 2N3055 and 2SD371 power transistors. Any ideas?
Thanks
Charlie
kenwood KR 77 specs & schematic
Hi Charlie,
Don here from TX. I just bought the same KW receiver and have the spec sheet and schematic.
Send me an email at ponies502000@yahoo.com and I will scan and email to you.
From what I see, it is rated IHF at 75W at 4 ohm, 56W at 8 ohm, Continuous power each channel driven at 24W each channel....
PS I like the name Charlie, it was my dads name.
Later, Don
KR-77 - I own two
The likely reason that your KR-77 is weak on one channel is because they used a first generation IC to route all of the audio through. That IC tends to go bad - your symptoms are classic. It's a ua703 - still available.
If you don't want the receiver I'd be willing to take it off your hands. There were two types - no black-out dial (early) and blackout dial.
I've owned one since 1970. I also look for them (and the KR-100) on Ebay and like restoring them. I always update the lamps to my LED fuse lamps.
You can see a photo of the front of my KR-77 on my auction at:
Item number: 9729369373 (note to moderator - I'm not trying to sell, I'm trying to buy his unit!)
If you need the schematic, I've got it on CD and could make you a copy.
DH
Thanks
Charlie
It says 24 watts
