EchoWars said:If the fuses are good, then it's either offset or protection circuitry problems.
EchoWars said:If the outputs are gone (which about always means shorted), it will eat fuses. If the fuses are good, then it's either offset or protection circuitry problems.
Make sure you check the protection relay itselfhotgas said:It sounds like I need to replace all the caps (9 or 10 total) :worried:
Punker X said:I've had about 8 2270's come across my bench with relay problems. 1 had shorted output transistors, on had a transistor bad on the relay board. The rest were the caps on the relay board. C807 and R816 form a time constant circuit that delays the relay 5 seconds after power on. I usally at the very least have to replace C806 and C810 to get a good snap in the relay. Small caps are so cheap I usually just replace the rest of the caps on the board while I'm in there with a soldering iron.
You can find a scat at www.dummyload.com.
X
hotgas said:Here are what I did last night. Clean the pots and then replace the caps one by one. Now the relay brd has all brand-new caps BUT the relay still doesn't click.
My concern is that this is a 24V relay why applying voltage is so high!
