Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Tube Audio
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 07-01-2011, 07:31 PM
tube-a-lou tube-a-lou is offline
AK Member
Harman/Kardon A500 Tube Amp
Hi all,
Went shopping today and someone had a Harman/Kardon A500
Tube amp, needs to be redone and the gentlemen said he'll sell it me
for $250.00, good deal, I always redo these tube's amps anyway so
what do you think??
Tube
  #2
Old 07-01-2011, 07:47 PM
wildone's Avatar
wildone wildone is offline
Learning as I go!
Well I have one, and will be using it as my bench amp. I have the matching tuner too. My A500 has the HK tubes still. I have not done anything with it yet, They say they are nice amps. Like 25w per ch.
Pics?
WO
  #3
Old 07-01-2011, 08:42 PM
AK Member
Hi,
No pics yet, haven't brought it home, looks to be in good shape, look underneath
it has those huge Sprague black beauty caps on it. the guy told me when he put it
on, one of the can caps started to smoke, so I guess that needs to be replaced and
all the rest!
Tube
  #4
Old 07-02-2011, 06:27 AM
GordonW's Avatar
GordonW GordonW is offline
Speakerfixer
They're really good, once they've been recapped.
I replaced every coupling cap, and every electrolytic cap (including the cans) on the last one I had on the bench. Total of 24 caps. Be sure and don't forget the little electrolytics in the preamp/phono stage!
It sounded magnificent afterward.
Regards,
Gordon.
__________________
“My definition of too much horsepower is when all four wheels are spinning in every gear.”- Mark Donahue
My AK Gallery Photo Page: http://www.audiokarma.org/gallery/sh...00&ppuser=1240
  #5
Old 07-02-2011, 06:38 AM
Wardsweb's Avatar
Wardsweb Wardsweb is offline
behind the scenes
These really are sweet amps once they have been recapped. Here is mine I used for years before giving it to Kamakiri.
Cap job
More pics and the matching tuner here:
http://wardsweb.org/misc/HK_A500.jpg
Audiokarma
  #6
Old 07-02-2011, 07:34 AM
buickguy62 buickguy62 is offline
AK Member
I've restored a number of these with input from Jim McShane. I replace at a minimum all the electrolytic and coupling caps, the balance pots and the diodes, and liberal use of De-Oxit. I have an Excel spreadsheet that lists the components and sources I use --it's a good place to start--you might have your own preference on component selection. PM me for the spreadsheet if interested, I also have the schematic if you need one. One trick I've found is to use two of the dual 50/50 ufd. 500V JJ can caps from tubesandmore (to replace C29 A&B, and C30 A&B). They are under $10 each (plus the clamps), they fit in the existing holes and allow plenty of room underneath for the additional caps-see pics--that area gets crowded if you put all of the replacement caps under the chassis. See pics.
Tom
  #7
Old 07-02-2011, 05:27 PM
AK Member
Hi all,
Thanks for all the info, I'm really thinking of getting it maybe I'll try to get
him down a little, how about the power tubes 7355 is there replacements,
would 6V6's be good or 7591, I've read that with a little mod you can use
6L6's??
Tube
  #8
Old 07-02-2011, 08:53 PM
Patrice B Patrice B is offline
AK Member
7591XYZ are known to be a good (and cheap) replacement. Some mods have to be done however to allow it.
__________________
Scott LK-72A, 222D, LT-110 and 350
Fisher X-100-2, FM200-B and 101-R
Harman Kardon A500
Heathkit's AA-100, AA-32
Eico HF-81 and HFT-90
Stromberg-Carlson ASR-333 and SR-445
Various: Electrohome, Telefunken, Clairtone, Fleetwood, Nordmende, Grundig, Knight, VOM...
  #9
Old 07-14-2011, 03:39 PM
AK Member
Hi,
Decided not to buy it, I'm going to stick with the Fisher. besides he would not
go down in price, it's odd the knobs are off, the front panel is off, the bottom panel
is off and the light button the the switch is missing, so that's it thanks for all the help
and I'll wait for a better one to appear.
Tube
Tube
  #10
Old 07-14-2011, 03:46 PM
GordonW's Avatar
Speakerfixer
Quote:
Actually, the only mod that is needed, is to snip off the one pin (from the base of the tube itself) that the 7591 (and 7591XYZ) uses, that the 7355 does not. IIRC, that's pin 4. Check with a good tube manual... it'll be the pin that's also connected to the screen grid, in parallel with the "normal" pin that's used for screen in the 7355. You only need one screen grid connection... so that one that's in the unused position on the 7355, can go away safely.
Regards,
Gordon.
__________________
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
©Copyright 2002-2015 AudioKarma.org, All rights reserved.
