NOSValves
tubino said:Nope, I regret that I didn't spend nearly enough time listening to that one and some others...
But yes, it's an interesting tube. Isn't it a low-mu high-current dual triode like the 6336, designed for use as a pass tube? I've heard several amps that use it, but mostly PP. I would guess that the OPT primary impedance doesn't need to be very high in any case.
It really was one heck of a nice sounding amp for the price of admission especially if SET is you cup of tea (If it is SET you have me wondering now). I'm not sure about the 6C33-B being a dual triode? I believe it was used in the Russian Migs as some type of Scope tube? The imformation on this tube is really slim out there on the net. It's funny you mentioned the 6336 my SET amp uses this tube one half per channel though very nice but way down in the power output compared to the 6C33-B the Almorro is rated at 18 watts but I'd be surprised if it really can do it. Heck if your right about the dual triode then maybe the Almorro is PP?
Craig
