beatcomber
AK Member
Our good friend Paul, aka thedelihaus, graciously agreed to perform his legendary package of upgrades on my SL-1200MK2.
Previously I had done some of my own simple upgrades: a.) wrapped the arm in rubber shrink tubing (made a BIG improvement); b.) placed the table on 1/2-sliced racquetballs to reduce feedback; and c.) inserted a KAB tonearm end-stub. Real basic stuff, but I wanted it to go further: namely rewiring the tonearm with Cardas and bypassing the circuit board, internally damping the tonearm tube; and replacing the stock RCAs with SL-1200M5G audiophile-quality RCAs. Once I got the wires and stuff from KAB, I removed the tonearm assembly and made plans to meet Paul at a local coffeeshop.
Let me interject here that Paul is one of the nicest guys around. It's been a great pleasure getting to know him offline, and the man really knows his stuff!
Paul contacted me earlier this week to let me know that the arm was done, and we made plans to meet at a different coffeeshop. (Paul is clearly a "caffeine achiever"!) Besides rewiring the arm with the Cardas, bypassing the circuit board joint with a KAB turret board, and adding the better RCAs, Paul also stuffed the tonearm (with cotton? I'm not sure) and stuffed some expanding foam ear plugs into the end of the tonearm, where it is known to have unwanted resonances. Around the solder joints he applied some sort of spray mount liquid tape, to insulate the wiring against hum. He also sprayed the same stuff on the lower armboard plate, to dampen it against vibration. Finally, he also removed my wonky shrink tubing job and redid the entire length of the arm a lot more neatly.
So how does it sound?
Before getting to that, let me say first that while the SL-1200MK2 was out of commission I was listening exclusively to my Linn Axis w/Basik arm. I also rotated a few carts on the Linn and did some needledrops to CD-R: a Shure M91ED w/Jico SAS and a Denon DL-160 (two VERY different cartridges) were used. Prior to having the mods on the 1200 performed, I had felt that the Linn sounded head and shoulders better than the SL-1200 for the usual reasons stated: the Technics sounded constricted, dark, etc.
Tonight I cued up the needledrop CDs I had made, and listened back and forth to the CDs and to the same LPs played with the same carts on the Technics - basically I wanted to see how well the modded SL-1200 stacked up against the Linn using the same cart on the same record.
They were VERY close! With both the M91ED and DL-160, the Linn had a touch more top-end 'air' or bloom than the modded 1200, but also sounded a bit lighter overall. The 1200 had better dynamic punch and fuller bass/midrange than the Linn. Imaging and soundstage presentation on both tables was about equal.
The differences were slight at best, and I can't say that one was necessarily better than the other!
I am very impressed with the new performance ability of my newly improved SL-1200, so much so that I will be giving some consideration about whether or not to sell the Linn and then reinvest in some additional KAB mods to the SL-1200 (ie: 78 speed).
Thanks again, Paul!
Thanks again, Paul!
