Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Turntables
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 07-29-2011, 09:08 AM
TheAppleChap TheAppleChap is offline
AK Member
Official Fix for Pro-ject Turntable rumble now available
The "S/E Upgrade Kit" from Pro-ject has now been launched that will put to bed, once and for all, any problems with low level rumble noise on affected Pro-ject turntables.
The kit comprising a replacement pulley and belt and rubber isolating grommets and screws costs £25 and is available from Henley Designs in the UK. It may also be available from your local Pro-ject supplier.
I was given access to the kit two days ago and the installation was simple, taking less than ten minutes and should be easily doable for anyone able to wield a screwdriver.
I have written an instruction guide and posted a full review on my blog at :
http://www.theapplechap.com/TheApple...Hz_rumble.html
Henley Designs describe the fix as "These simple additions help decouple (isolate) the motor from the turntable plinth. By doing this, unwanted vibrations from the motor are dramatically reduced, allowing the sub-platter to spin truer, and the tonearm to transmit the sound signal better."
Enough to say that on my turntable there was a complete removal of ALL low level rumble, shoring up the bass, making it deeper and more controlled.
I would thoroughly recommend this kit to all Pro-ject owners with compatible turntables.
I'm grateful to Henley Designs for agreeing to lend me the necessary parts and let me review them and post the article on my blog. I have no professional relationship with Henley Designs and had a free hand to write the article. Therefore all errors and omissions are mine and mine alone.
Cheers
Alan
  #2
Old 08-02-2011, 10:58 PM
SteveinMN's Avatar
SteveinMN SteveinMN is offline
AK Member
As a Pro-Ject TT owner, I thank you very much and bow in your general direction. :-)
__________________
This is only temporary -- unless it works!
-- Red Green
  #3
Old 08-03-2011, 01:09 AM
avole avole is offline
Banned
Can't help feeling Pro-ject have come very late to this and it has done some damage to their reputation.
I sold on my Debut III some years ago because of the high level of motor noise, as I suspect others have too, and have been recommending against the cheaper Pro-jects since. I also think it's expensive since the problem was a design fault - if it were an automobile, this would have been done in a recall for free.
Is this now a standard modification for all their cheaper decks?
  #4
Old 08-03-2011, 02:08 AM
Mr. Lin's Avatar
Mr. Lin Mr. Lin is offline
AK Subscriber
Quote:
I agree. But is this even officially from Pro-Ject?
Even my RM-5 has this issue when played at 45rpm. I didn't notice it for a long time because it's not that loud, and I don't often play records at that speed. I'll probably look into this kit, the sonic strengths of the RM-5 make it well-worth keeping, and spending an extra $25 or so.
__________________
  #5
Old 08-03-2011, 05:01 AM
drknstrmyknight's Avatar
drknstrmyknight drknstrmyknight is offline
Frank
I wonder if this would help out Music Hall's MMF5?
I believe they share components with the Projects
__________________
Living room: Squeezebox touch, Music Hall MMF5, Goldring 1042, MX110Z, McIntosh MC225, LaScalas
Mancave: Pioneer 510A, Ortofon Super OM 30,Shure M65 clone, Eico AF4, Fostex FE206E BLH's
Audiokarma
  #6
Old 08-03-2011, 07:45 AM
eteller's Avatar
eteller eteller is offline
but wait there's more
Personally while I feel Pro-Ject should be offering this as a FREE retrofit for all existing owners, two blobs of sticky tack rendered mine silent. Nice work BTW Applechap!
__________________
Ed
Amateur Audio Hoarder
  #7
Old 08-05-2011, 09:28 PM
Mr. Lin's Avatar
AK Subscriber
Quote:
Hmm, I tried silencing mine with some extra Herbie's db Neutralizer material, and it didn't seem to help at all.
I've just set up my RM-5 for the first time in about one and half years. Listening with headphones, a little bit of the rumble/surface noise is audible even at 33 rpm. My Thorens has it beat in that department, but in detail, refinement, resolution, and natural sound, the Pro-Ject wins (same cartridge being used btw).
__________________
  #8
Old 08-05-2011, 09:47 PM
Mr. Lin's Avatar
AK Subscriber
Whoops - just realized a minute ago I forgot to level the tt. That got right of a good portion of the hum/noise.
__________________
  #9
Old 08-06-2011, 10:01 AM
Ant1-Hero's Avatar
Ant1-Hero Ant1-Hero is offline
Prince of Tubes
Looks like its only available in the UK
__________________
Pro-Ject Xpression III | Jolida JD9 | Denon DL-160 RCLC
Yaqin MC-10L MkIII w/ 6P3S-E / 6CG7 / 6N1P
Harman Kardon TD-4800
Epos MT12i | 8TC | Morrow
  #10
Old 08-10-2011, 05:56 PM
gvalent's Avatar
gvalent gvalent is offline
AK Member
A little late on this one!
Too late for me.
I unloaded my Project TT awhile back because of the motor hum issue. This was the most annoying piece of audio equipment Iíve ever purchased.
I lost all respect for Project gear and Sumiko, the most worthless distributor of product Iíve ever been involved with.
__________________
My questions are always answered. My comments always ignored.
Audiokarma
  #11
Old 08-10-2011, 09:52 PM
Mr. Lin's Avatar
AK Subscriber
Quote:
Originally Posted by gvalent View Post
Too late for me.
I'm going to ignore that comment (just kidding ). Remind us which Pro-Ject turntable you had?
__________________
  #12
Old 08-10-2011, 09:59 PM
Bob_in_OKC's Avatar
Bob_in_OKC Bob_in_OKC is offline
AK Member
This fix is for the turntables with the motor suspended on a resilient ring, which would not include the MMF-5. I once owned an MMF-5 and it didn't have this particular problem, which made me wonder if Pro-Ject wouldn't be better off mounting that motor the same way Music Hall did.
  #13
Old 08-10-2011, 10:43 PM
Mr. Lin's Avatar
AK Subscriber
Quote:
If I understand it correctly, I think the kit bypasses the motor suspension altogether.
I just finished a new thread topic that's very relevant to this discussion:
http://www.audiokarma.org/forums/sho...d.php?t=386585
__________________
  #14
Old 08-11-2011, 12:23 AM
Bob_in_OKC's Avatar
AK Member
I would guess this fix could be accomplished with a few silicone grommets and no special kit. You could put two silicone grommets under the flanges of the motor, put two more grommets and maybe two washers on top of the flanges, re-install the transport screws (not too tight). The round belt and alternate pulley might be a slight upgrade, but don't look essential. Cost of a small pack of grommets would probably be under $5.
  #15
Old 08-11-2011, 01:59 AM
gvalent's Avatar
AK Member
I had an Xpression lll.
I noticed the hum after about six weeks. I couldn't get it out of my head after that.
It was really annoying listening to classical music..... Bulgarian death metal...not so much.
__________________
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
AV Solutions
FM DX Antenna
Musical Paradise
Grant Fidelity
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Urban Antigue Radio
The Tube Store
Many Moons Audio
Audio Doctor
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
©Copyright 2002-2014 AudioKarma.org, All rights reserved.
