battradio
Electron trainer
My Snells haven't sounded right for a long time , the previous owner made quite a mess of the them , he blew the woofers before i got them and at the time I put some mediocre replacement woofers in them .After taking them all apart and doing some reaearch , the front and rear tweeters had been exchanged . I tracked down a pair of Vifa 8" woofers close to the originals , one of the front tweeters had been replaced with a factory replacement but the magnet structure was different , so i located a pair of originals.
After pulling the crossovers to order new poly caps to rebuild ithem i found the 33MFD nearly open .This is why one of them sounded rather wierd , the front tweeter crossover is a little strange compared most i have seen , the rear tweeter crossover is just a 3 DB with a 3 MFD cap and a one ohm resistor .The woofer crossover is prety striaght forward with a 1.38 MH inductor and a 15.25 MFD cap .
There are a lot of crossover calculators on the internet to get the capacitor and inductor values when you have the crossover points are there any that if if you have the inductor and cap values that it will give you the crossover freqincies .
