The 'adventure begins', lol, just bought a modded 240 amp...
RickJ_2270
I just purchased this fully serviced and somewhat 'modded' Marantz 240 from that auction site. Some of you perhaps saw the listing. I'm guess I'm taking a bit of a chance on 'untried/untested' mods, but what the heck, how bad can it be? Different is good. Here's a summary of the work done. It should be arriving in several days. What do you think? Personally, I'm looking forward to the adventure, lol, and hopefully some 'warm tube-like sonics'.. Wish me luck.
Up for your consideration, is a one-of-a-kind Marantz Model 240 Stereo Power Amplifier. Conservately rated at 120 watts RMS per channel at 8 ohms. The Model 240 has been known to deliver more than the rated output. Already a classic, rare, vintage, Marantz model, this unit has been throughly serviced. All questionable parts were replaced. This includes new high frequency Panasonic electrolytic capacitors, polystyrene film capacitors, polyester film capacitors, silver mica capacitors and any questionable resistors. All transistors are either the original devices or Marantz approved OEM type replacements. Moreover, the often troublesome output relay was replaced with a new OEM type whose contacts are free from any corrosion. The relay provides solid contact for maximum signal transfer from the outputs. The RCA input connectors were replaced with high quality jacks, thus eliminating the troublesome original types that were prone to corrosion and poor signal transfer.
If all these serviced items weren't enough to greatly improve this vintage amp, this Model 240 has been modifed with the addition of an ultra high quality power supply modification that decouples the output power supply from the input stages by providing a separate, regulated, high performance, 18 volt D.C supply to the input stages. Originally, one power supply provided power for the entire amplifier, thus limiting it performance and sound quaility. Now, with the additional power supply, the sound quality has been transformed from comparative "transistor" like chacteristics, to a much darker, warmer sound more closely resembling tube sonics.
This change in sound quality is a result of a rear mounted, high-current, dual secondary toroidal power transformer supplying (2) 24V lines to (4) low noise, ultra high speed diodes to form the dual bridge rectifiers. The 24 volt lines are reduced to 18 V.D.C. via (4) ultra high quality, Linear Technology low dropout voltage regulators. Each channel has separate regulation stages for both positive and negative voltage supplies. This configuration greatly reduces noise and improves sound quality by eliminating the usual power transformer center tap direct connection to ground. Now, due to the dual secondaries, dual bridge rectifiers per channel and dual regulators per channel arrangement, the bridge rectifiers commons are D.C. in nature not A.C. as was before. This is a much cleaner arrangement, opening up the potential of the Model 240 that wasn't possible with the previous configuration.
The original input power supply was fed from the output stage supply line, through a dropping resistor, then zener diode regulated. While this arrangement was adequate in its day, it can't compare to a separate, low noise, dedicated, 2 channel, regulated power supply, that specifically feeds the input stages of the amp, while freeing the main power supply to drive the output sections.
All components are of first rate quailty and mounted on high quality fiberglass printed circuit boards. Separate fuses are used for the input power supply and main power supply. The bridge rectifiers are International Rectifier ultra high speed, low noise, high current devices. Linear Technology LT 1085 and LT 1033 low-noise, low drop-out devices are used for the positive and negative 18 volt regulators. Additionally, the original bridge rectifier diodes for the main supply were replaced (see pics) with low noise, ultra high speed, high current, International Rectifiers diodes to help reduce noise in the output stage supply. High quality Panasonic capacitors are used throughout, for filtering the A.C. and for long life. The high current, torodial, rear mounted power transformer is protected by an attractive, heavy gauge steel covering, ensuring protection and isolation. The A.C. power cord was replaced with a compatible OEM type style. The original (2) 20,000 mfd. main power supply capacitors are in excellent condition. They show no signs of leakage.
The cosmetic condition of the Model 240 is very good to excellent, as the pictures show. The faceplate is very good to excellent, with only minor flaws not easily seen. The unit is very clean.
Thanks and regards, -rick..
The 500 is the only Marantz that I have seen that has a separate set of Transformer windings for the early stages of the AMP, as you mentioned below. It has it for the very critical Amplification stage.
So yes the early stages can be adversely affected by the power demands of the output stage. By separating them, the earlier stages can stay "One Step ahead" of the power stage.
I have seen a only a very few other design that go to that level of consideration.
Its more like having a separate Pre-amp, MID-AMP and Power Amp..... The 500 was the earliest design I have seen like that, there a few others that I have seen that included a Mid Amp supply. The 500 has some other Marantz sound secretes too.
Your 240 should really perform very nicely.
jk
RickJ_2270, Congratulations on your new to you Marantz 240!
Will be waiting for your listening impressions.
Seem to remember some one posted about these types of modes to a 240 before. You might want search and ask their opinion.
Jk
Hey guys,
Thanks for the kind comments. I'm looking forward to listening to the 240 as soon as it arrives. I will be sure to post my impressions. I'll be connecting it to a Marantz 3600 pre-amp. I also have a Marantz 250 amp hooked up to the 3600 at the moment, so I will be able to do some comparisons as well.
I've got the pics from the seller, so I figured there'd be no harm in posting them here especially since I am now the owner of the unit. The outboard power supply looks a bit weird at first sight, but once I have the 240 hooked up, I don't plan to spend a lot of time looking at it, lol.
I am not an electronics engineer, or a repair technician, but even to my eyes, this 240 looks incredibly clean on the inside. Thanks for looking!
It certainly looks like someone put a lot of though, time and effort into this modification. Did the seller provide any information on who did the mods?
Did the seller provide any schematics of other detailed information in case it needs to be worked on in the future?
Wow.... some one really pulled out all the stops on that one.... :)
I would think some of those extra filter caps are a bit of over kill.... But I do believe in "too much is never enough...." so rock on.
What speakers are you planning to use with it...?
You know once the snow ball starts rolling down hill.... the other components need to be upgraded too. But you knew that... whats next? Don't hold back! :D
jk
Can you post a pic of the right side amp board that you had opened? Would be interesting to see what the mods to the amps were made.
jk
It certainly looks like someone put a lot of though, time and effort into this modification. Did the seller provide any information on who did the mods? Did the seller provide any schematics of other detailed information in case it needs to be worked on in the future?
You know, I've been wondering if the restoration work might have been done by someone who posts (or advertises) here on the AudioKarma Marantz forum, lol.. :)
Good point. I will contact the seller to see if he can provide me with any schematics and/or other pertinent documentation.
-rick
Wow.... some one really pulled out all the stops on that one.... :) I would think some of those extra filter caps are a bit of over kill.... But I do believe in "too much is never enough...." so rock on. What speakers are you planning to use with it...? You know once the snow ball starts rolling down hill.... the other components need to be upgraded too. But you knew that... whats next? Don't hold back! :D jk
I have had a Marantz 'connection' for a long time. In 1975, I bought myself a brand new 2270 upon graduating from college. I kept it for around 20+ years, and finally gave it to my brother as a gift. I used it with Rectilinear III speakers, and a Dual turntable, which I also bought in the summer of '75.
In 1995, I bought an Acurus amp & pre-amp, and a pair of Maggie 2.7qr speakers from a small dealership in Huntsville, AL. They have served me pretty well along with my NAD 5000 cd player.
Guys, I regret to state that I had a very sad, emotional 'life event' occur about a year ago. I suffered the unexpected loss of my wife last summer. We were married for 21 years. Please cherish your loved ones every day that you can!
After my wife passed last summer, I needed something to take my mind off my loss, so I decided to start collecting vintage Marantz equipment. Because my original Marantz 2270 was purchased at a time in my life (college graduation) when I was extremely happy and optimistic, the act of getting into Marantz collecting in 2010 brought back good lots of good memories. Obviously, nothing can replace a loved one, but I have always loved music and electronics, so this has--in part--been 'an escape' for me.
Among other items, I came across a wonderful, beautiful, fully-restored Marantz Model 18 receiver a few months ago. The previous owner had it totally restored by Terry DeWick. It is just stunning and sounds awesome. Since I originally started out my collecting life with a 2270 (in the 70s), I never knew anything about the earlier Marantz models that were made in the era that was one generation prior to the 2270 line. It is really fascinating to see some of the formative design elements in the Model 18.
In recent months, I have also picked up a 2325, a 2330b, and a 2385. One of my first acquisitions last summer was a mint condition 2265b receiver. Prior to buying this, I had never seen any of these 'all silver face' models in my life because after I bought my 2270 in 1975, I spent the next 15 or so years focused on getting a career going, and I didn't really pay attention to Marantz for a while. I gotta tell you, though, the 2265b is an amazing little receiver!
In the past year, I have acquired three sets of speakers to supplement my Maggies. A pair of Martin Logan Aerius, a pair of JBL L65s, and a pair of JBL L150s. I found the ML speakers on Craigslist. The seller was located less than 3 miles from me, lol. The two pairs of JBL speakers were puchased from a serious Marantz collector in Minneapolis who I came to know after buying a Martantz 2130 tuner from him.
The ML Aerius speakers are just awesome. The JBL L65s are a bit too bright for me, but the JBL L150s are just awesome. Warm, accurate, detailed.
Since I am already using the Aerius speakers with the 2325 (and alternating with the 2385), I think I may try the L150s with the Marantz 240.
Thanks for asking.
Regards, -rick
Can you post a pic of the right side amp board that you had opened? Would be interesting to see what the mods to the amps were made. jk
Hi jk,
I just bought the 240 the other day, and it is currently in transit from Utah to my house in Nashville. The pics I posted above were either taken by the previous owner, or by the person who did the work. When I take delivery, I am going to be really paranoid about opening it up, since I don't have a clue what I'm doing.
So far, the only mods I have done to any of my Marantz purchases, have consisted of installing some new feet, and installing some faceplate bolts on one of the receivers that arrived with a few of them missing in action, lol.. :)
Best regards,
-rick
Around every corner is another challenge and reward. Meet both with the same love for life...
JBLs and Marantz..... That is a real sweet spot....Don't forget a world class source too....
You're not using a 49$ DVD/CD player from Wall-Mart....even though their headquarters is near you.... ? :)
jk
Around every corner is another challenge and reward. Meet both with the same love for life... JBLs and Marantz..... That is a real sweet spot....Don't forget a world class source too.... You're not using a 49$ DVD/CD player from Wall-Mart....even though their headquarters is near you.... ? :) jk
Lol, no absolutely not.. I recently acquired a Rotel 1072 cd player (new in box). I actually heard it last autumn (on a road trip to Atlanta to buy a 1250 int amp from a seller on CL). The 1250 seller invited me into his home to demo the 1250 for me. He happened to have a Rotel 1072, and I was blown away by the warm sound. I bought the 1250 from him, and a few weeks later, I found a 1072 of my own. Fyi, this is the car I drove to Atlanta in. The seller really wanted to see it..
To keep ther Marantz loyalty going, I also bought a Marantz SA8004 cd player last Christmas.
I also just acquired a Marantz Music Link system, and there is a cd player in there, which I haven't had a chance to hook up yet. Maybe the incoming 240 will give me an excuse to debut the Music Link cd player.
I also picked up a 6300 turntable which I will hook up eventually, after I get the cartridge installed.
Rick
928 is a very cool car, it is the only street Porsche that I lust after.... But short of a 917.... I am staying a Ford guy ( the stang in the jstang ).... :D
Thanks for asking.
Regards, -rick
Really sorry to hear about the loss of your wife.
Do you have any internal pics of the Model 18?
Does your L65 have the glass tops intact?
Unfortunately, I have no pics of the internals of the Model 18. I've been meaning to take a few pics of the faceplate and post them here on AK.
The L65s did indeed come with the glass tops, although the seller had them carefully wrapped, and I haven't gotten around to unwrapping them, lol..
We were both a bit worried about shipping this stuff, so I actually rented a mini van back in April, and with my golden retriever along for the ride, I drove from Nashville TN to Bloomington IL to meet the seller and take delivery of the 2 sets of JBL speakers, and the Marantz stuff (models 18, 2325, 4300, 1250, 300DC, 6300, and a full Marantz Music Link system). As a bonus for buying a lot of stuff from him, he threw in a complimentary 4230 quad receiver, lol..
Regards, -rick
You guys have some impressive stuff.Most of my stuff Ive had since the early 90s.Except the techwood and marantz units.
