what if you used silver wire or silver interconnects as jumpers? would that be good or bad?
Pure Silver, per se, is the best conducting metal on the planet. It's really excellent for audio purposes. I make up my own, because I know how to make it happen, and have the metals backround.
However, you would be hard pressed to find this gauge wire in pure silver anywhere. One *might* be able to find the gauge in *Sterling*, which has Copper added and is the usual alloy found around being used(it makes the final blend harder for function durability). Copper is the next best conducting metal. However, the Copper added to Silver makes the final blend prone to tarnish. Copper is inherently a very dirty metal, and very difficult to refine clean. It's why great efforts are usually taken to *electroplate* the Copper parts, simply trying to prevent oxygen from reaching the Copper. If no oxygen reaches the Copper, it doesn't corrode. Gold is usually used as one plating choice, it never tarnishes. Gold passes a signal better than Rhodium, which is getting expensive. Less noble metals get used as cost cutting happens, Nickel, chrome, etc... But those impact the high frequencies which travel on the surface(s)
Easy way to clean Copper or Sterling is to get a cheap bottle of a Tarnex-type product. It smells like rotten eggs<g>, but it's easy to just dip the parts in the stuff, they clean in seconds, rinse well, dry well, and just slide them back in the stereo.
Fwiw,
pure Silver oxidizes a white frosty color... These oxides do not impede an electrical signal, completely contrary to Copper oxides
fwiw again, I just picked up a Pioneer SA-9800 integrated amp. It's a wonderful piece. It came with the stock jumpers. I listened for a while that way. Then I redid the music after taking out the stock jumpers, and put in some pure silver ones. I could certainly tell the differences!... It's just one more thing that can be done to help the music pass by cleanly.
It's just the way it is using pure silver for audio purposes.
Problem is, manufacturers(ooh la la *designers*) who make up the stuff for retail market, usually charge obscene prices for their products, giving Silver a bad rap.
