Built one of these today following this link, which I believe has been posted here before:
http://antiqueradio.org/dimbulb.htm
I followed the schematic and a couple of other articles I found with a Google search, but wanted to check to make sure I got it right.
Here's how I wired it:
-- hot from plug to copper screw on SPST switch.
-- hot from second copper screw on switch to copper screw on light bulb fixture.
--hot from second copper screw on light bulb fixture to copper screw on one outlet plug.
-- broke the tab on the copper side of the outlet as per instructions.
-- neutral from silver side of outlet to wide blade of plug.
I built it to test the recap I had done on my Marantz 1060. I used a 65W bulb which was the lowest wattage I could find. When I flipped the switch on the tester, there was no light from the bulb, but the power diode on the amp lit. I was a little concerned because I would've thought that if the bulb wasn't lighting it was drawing all the power and the amp diode shouldn't light.
I shut everything off and then, like an idiot, unscrewed the lightbulb and flipped the switch back on. Again, the diode on the amp lit. I shut it off very quickly.
When I connected the amp to my speakers and an input source, it worked fine, so I know the amp is OK. I'm more concerned about whether I built the tester correctly.
Any comments or suggestions would be greatly appreciated.
Thanks,
Jack
Thanks,
Jack
