I have an x-355. I've never seen another like it, not even close in fact, for solidity of build - seriously, this thing is Heavy Metal. Looks military, not least because of the battleship grey of the face and case!
The heads are metal, and can suffer wear.
As noted, a recap (at least of the audio i/o stages) will be almost essential - but most are located on cards which slide out the bottom, it is user-serviceable in that regard.
Also the capstan belt will probably need changing, it is quite fussy about the exact type. Too thin and the speed won't change properly as it rides the pulley.
The brakes on mine need attention, which is partly why it is out of use at the moment.
The solenoid controls are nice, and responsive. I am not a fan of Akai's clumsy 2-lever designs on their cheaper models. Like vfr800fiman, I prefer electronic controls.
The relays' contacts may need cleaning, but these relays do not generally go bad. They are easily reachable thru the rear.
And yes, I found the winding speed to be absurdly fast, and there is no tacho or anything measuring spool pulses to slow it down, so beware. Not one to use your triple play 0.5 mil tapes on!
So, in short, worth considering as it has a great sound and build, but due to age it will need a fair bit of work. One for the techs amongst us.
And, if anyone happens to have a manual....
