markus
Master Procrastinator
I've been sitting on these for a loooooong time . . . they've scared me from the day I brought them home :yes: there's a reason those tubes are behind a cage . . . I figured it was time to leave the kiddie pool and see how the deep water is . . .
a quick rundown of the spec's, that I know of:
4 809's in Class B / Push Pull Parallel for output tubes
2 2A3's to drive those 4 Transmitting tubes
1 6SL7 as (i think) a phase splitter and voltage amp
3 5R4's in the power supply, putting out WELL over 600 VDC . . .
designed to run a complete drive-in theater, the rated frequency response is 50-5000 Hz, at 125 watts RMS. When I got them, they were missing most of the tubes. Over the years, I snagged a pair of Valve Art 2A3's, 4 5R4's, and a few 809's (already had a couple 6SL7's kicking around . . . )
I still need to track down 2 more cheap 2A3's (new production of course) and 3 more 809's (ideally I'd have 8 'matching' NOS 809's, as I see no way to adjust bias on the 809's . . .) two of 809's I DO have separated from their top caps, so for testing, I soldered the plate wire coming out of the top of the 809's to the plate cap socket.
I brought the first up on my variac, and although there is a substantial low level buzz (sounds like a ground issue, not a power supply issue), it is making music through my test speaker. Clearly, it'll require a recap - power supply uses all BIG oil caps, and the signal caps are all 1000V which I don't trust AT ALL
The plan is to get the remaining tubes I need over the winter, recap both amps, and bypass the input transformer, which I believe is the circuit component limiting the frequency response and see how well they sing. With iron this serious, I'm very hopeful :thmbsp:
