Fasterdamnit
The GW find JBL L36's have had a few days of operation after a full recap and replacement of the "binding posts" for actual binding posts. All three speaker sets sport Dayton poly caps in the x-overs.
This is a first installment review using my Magnavox 9302 fully mod'ed with Edcor OPT's. I picked a track from the regular rotation stack of vinyl and Dire Straits, "Industrial Disease" hit the platter.
The JBL L36's from around '77 and the Polk Monitor Series 2 from around '88 both were models built to provide "high value", affordable speakers. I think the Polks have a '92 production date on them. Two different approaches:
JBL- 3 way with 10" woofer on ported cab. Paper cone tweeter and mid. Big foam ring around the tweeter. :thmbsp:
Polk - 2 way with 6 1/2" mid woofer and a passive 10" radiator in sealed cab. Textile dome tweeter, small foam ring and concave housing in relation to the baffle.
The L36's have the mid and tweet side by side- very close to the woofer. The Monitor 7's are a more traditional vertical stack. Both are driven nicely by ~15W of PP tube amp.
Specs:
Polk Monitor 7 Series 2
Driver Complement
Subwoofer 1 - 10" Diameter (25.40cm) sub bass radiator
Midrange 1 - 6-1/2" Diameter (16.51cm) driver
Tweeter 1 - 1" Diameter (2.54cm) Polk SL2500 dome tweeter
Electrical
Overall Frequency Response 25Hz - 25kHz
Lower -3dB Limit 40Hz
Upper -3dB Limit 23kHz
Nominal Impedance 8 ohms
Recommended Amplifier Power 20-150 w/channel
Efficiency 89 dB
Cabinet Size 24" H x 13" W x 10" D
(60.96cm H x 33.02cm W x 25.40cm D)
Shipping/Other
Total Shipping Weight 33.00 lbs. (14.97kgs)
JBL Decade L36
Decade L36 is the largest in the "Decade" concept.
Specifications:
Manufacturer: JBL-James B. Lansing, California USA (1975)
Principle: Bass reflex
Number and type of speakers:
Woofer: (W) 125A, 250 mm/10" diameter
Midrange: (M) LE5, 130 mm/5" diameter
Tweeter: (T) LE25, 35 mm/1.4" diameter
Crossover points: 1500 and 6000 Hz, variable mid and tweeter controls
Volume in litres: 45
Bass own resonance of the box: 30 Hz
Frequency range of the box: 30-15000 Hz ± 3 dB
Power rating: 35 W
Maximum power: 50 W
Impedance: 8 ohms
Dimensions: 340 x 610 x 350 mm/ 13.5"x 24"x 13.625"
Weight per piece: 18 kg / 38lbs
Sensitivity per JBL technical page: 76db at 1 watt at 15 feet. (They sound like they match the Polks when swapping A to B.)
We have JBL's renowned expertise vs. Polk with a decade of technological advances and much more robust computer modeling available.
The RS6000's will be a postscript as they need waaaay more power than my tubes can provide to really wake up.
First some pics then I will post some musings on what I heard.
itty bitty stock JBL connectors and the new PE binding posts that happen to fit the opening the original posts were in perfecftly!
The gang (poor phone pic)
Specs:
Driver Complement
Electrical
Efficiency 89 dB
Shipping/Other
JBL Decade L36
Specifications:
Power rating: 35 W
Maximum power: 50 W
Impedance: 8 ohms
