Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Tape
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 11-04-2011, 07:12 PM
reeltoreel68's Avatar
reeltoreel68 reeltoreel68 is offline
AK Member
Question Marantz Pmd 430 cassette deck ac power supply
I have the possibility of purchacing a Marantz pmd 430 stereo deck. the sell says it works well on batteries but has no Ac power supply. can it use a universal Adaptor or is it a special voltage?
__________________
Reel to reel . once you get the bug, there is no cure. you must keep feeding the addiction.
  #2
Old 11-04-2011, 07:16 PM
petehall347's Avatar
petehall347 petehall347 is offline
the brandy coffee man
it will have to be correct voltage and amps ..more amps is ok less isn't . voltage within 1 volt is maybe ok ..hope that makes sense
  #3
Old 11-04-2011, 07:25 PM
soviet123's Avatar
soviet123 soviet123 is offline
AK Member
Someone online says 4.5 volts for this deck.
  #4
Old 11-04-2011, 07:34 PM
skibjr's Avatar
skibjr skibjr is offline
Silversmith
Marantz DA-36 is the original adapter - 4.5VDC, 700mA. There are two of them on eBay right now for $9.99...
  #5
Old 11-05-2011, 10:27 AM
bobschneider's Avatar
bobschneider bobschneider is offline
AK Member
Or you can buy a brand new one from Superscope for $20. They'll also service your deck. I had them do mine, and am happy with the result.
http://www.superscopetechnologies.com/t-parts.aspx
__________________
Mac MCD201, MR78, C41, MC352, MPI4
ML Ascents + Descent, Linn LP-12, Revox B77, Squeezebox Touch
Citation 1 & 2, Marantz SA-11S2, Technics SP-15, Onkyo T-9090II, PMC OB1i, Otari MX5050 B-3, Squeezebox Touch
Audiokarma
  #6
Old 11-06-2011, 11:32 AM
sssmokin99's Avatar
sssmokin99 sssmokin99 is offline
AK Member
I have one of these- IMO, it is worth getting the correct power supply. There wont be any more three head, dbx, portable cassette recorders coming on the market ever again.....
__________________
Marantz-Klipsch-Teac-Akai-Yamaha-Dual-Ortofon-Miracord-dbx-Salamander & Barzilay Furniture (modded)....and car audio
  #7
Old 11-06-2011, 11:47 AM
jlb2 jlb2 is offline
AK Member
Hi, I had a 230 for years, that I used to power using a regulated universal adapter, with the correct voltage setting and plug. It worked like a charm. I don't think the original adapter would add anything more than being genuine, it was an ordinary design.
If I remember correctly, the best voltage setting was 6V, not 4.5V, Which makes sense since there was a 4.8V accessory battery that was supposed to be charged internally from the power input. 4.5V was not enough to fully charge it.
  #8
Old 11-07-2011, 03:16 PM
sssmokin99's Avatar
AK Member
Interesting point. I never had the rechargables, so would have never known. My point was simply that he could get a "genuine" PS for a reasonable price, still. It is a great deck....
__________________
  #9
Old 11-08-2011, 07:23 AM
AK Member
I just measured my original AC adaptor, and it's putting out 6.6 volts.
__________________
  #10
Old 11-09-2011, 11:20 AM
chan tran chan tran is offline
AK Member
I believe the original adapter isn't of the regulated type and thus measuring the voltage without the load would read high. With a well regulated power supply I would want to set it for about 5V.
Audiokarma
  #11
Old 11-09-2011, 02:48 PM
AK Member
chan tran you are correct, the original PS is unregulated. 6.6V is the voltage with no load connected, while the quoted 4.5V is when fully loaded (which is never supposed to happen in normal use, there is always a safety margin, sometimes substantial). In actual use, the voltage can be anywhere between 4.5 and 6.6V. The usual power blocks don't have a 5V setting, but the proper voltage is not difficult to find really: there is a battery voltage check button on the recorder, you set the voltage for the needle to be in the right zone of the meter. I have just had the opportunity to check a CP230 with a regulated power block, here are the results. With 4.5V you are just in the bottom of the safe zone: the deck works ok, but FF and rewind are fairly slow. With 6V you are in the upper part of it, everything works fine. With 7.5V the needle exceeds the top of the scale, so I don't consider it safe. I'd go for 6V.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
McIntosh Cabinets
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Audio Doctor
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
