I broke ground, so to speak, on this project. This is a AM/SW radio. After a little dusting (much more required) I disconnected the speaker from the chassis, then removed the chassis from the console.
Tubes have been removed. Immediately discovered one has a bad pin (6SK7). I have some of those available so no big deal.
Here's the lineup:
Coronado 6SK7
Truetone 6SK7
Wizard 6SQ7
Wizard 6SA7
RCA 5Y3GT
CBS 6V6GTY
Questions:
Any guess on the age?
What are the chances I can find a schematic?
What needs to be replaced and what can remain? I assume all the caps need to go. Resistors have probably drifted. Not sure what power rating the resistors are. All the wiring insulation is extremely brittle so that will have to be replaced.
Whats a good way to test the transformer?
I've dubbed around with new tube amps a little but never have tried a rebuild before. I don't think this has been plugged in for decades based on the condition of the power cord. (I can safely say it's been several years anyway). Any chance there's still a charge in the caps? Should I ground the chassis and then ground the caps?
I'm going to have many additional questions so please be patient with me!
I want to add an aux input. On another thread it was stated that's an easy mod, by connecting to the power switch, I believe. I've included several pictures.
If more are needed for illustration, let me know.
Thanks.
Rob
Here's the lineup:
Coronado 6SK7
Truetone 6SK7
Wizard 6SQ7
Wizard 6SA7
RCA 5Y3GT
CBS 6V6GTY
Questions:
Thanks.
Rob
