Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > DIY
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 11-26-2011, 10:54 AM
Sheddingskin's Avatar
Sheddingskin Sheddingskin is offline
AK Member
DIY PA style speakers
I'm going to have a lot of time on my hands over the next 4 months and I've got the itch to make something, so I think I'll tackle a new set of speakers.
I want to build a pair that, if I like them enough, will replace my CV DX-5's or be used in addition to them. I would like to get at least as much bass out of them as the CV's, but I want a wider, more encompassing sound if that makes sense. I know a lot of it has to do with the raw power and set up, but I want something closer to the sound that you get from sound reinforcement at concerts. Loud, chest thumping, clear sound that seems to surround you.
As far as power handling I'd like it to be fairly high as they will be powered with a Crown XLS-402 amp for now and probably another more powerful pro amp in the future.
I should mention that I mainly listen to electronic music and metal, with classic rock and alternative thrown in there for when I just want to chill out.
Are there any plans for anything that would fit this already out there? Or can anyone make any recommendations? I don't have a price set yet but the cheaper I can do this for while still sounding good the better.
Any help would be appreciated!
__________________
Brad
  #2
Old 11-26-2011, 02:05 PM
donprice donprice is offline
AK Member
eWaves with pro-audio woofers will get you part of the way there. Add a killer sub or two to really round out the bottom end. Here's a couple links to look at in addition to the mega-thread over in the speaker section.
DIY:
http://techtalk.parts-express.com/sh...ghlight=mettle
4pi kit:
http://www.pispeakers.com/catalog/pr...roducts_id/108
The eWaves can be pretty cost-effective if you have some woofers or cabinets you can recycle.
  #3
Old 11-28-2011, 10:05 AM
GordonW's Avatar
GordonW GordonW is offline
Speakerfixer
I've built stuff like this, quite frequently.
I'd recommend a good set of 12" or 15" woofers, and an E-wave high-frequency setup.
I custom-build (recone) woofers just for this. I have a cone kit that I absolutely love in this setup. I've built 12" and 15" versions, into woofer frames from various manufacturers. Power handling limited only by what woofer frame you start with. PM me for details...
Regards,
Gordon.
__________________
“My definition of too much horsepower is when all four wheels are spinning in every gear.”- Mark Donahue
My AK Gallery Photo Page: http://www.audiokarma.org/gallery/sh...00&ppuser=1240
  #4
Old 11-28-2011, 09:06 PM
jocko_nc jocko_nc is offline
AK Member
I would go with subs, EQ them and run with independent amps. That will make the cabinetry and crossover work so much easier. You can add or subtract pieces as you want. It is no fun having to re-work a large cabinet a couple of times.
I DJ's a party a couple of weekends ago using (what turned out to be a pile) of my vintage stuff: Klipsch Heresy on pole stands. (Don't fault me, I got them with the flange in the bottom.) 1x15 DIY Eminence bass cabinet. 2X10 DIY Eminence cabinet. The problem was getting the two bass cabinets to behave. I ended up with a separate amp channel and EQ for each. Mid bass punch to the 10's. Thump to the 15.
Man, it really sounded sweet in that large room!
The Heresy is a fine sounding speaker in its own right, the main issue being bass. Much better sound quality than a typical plastic PA speaker used by DJ's. Plenty loud when run with subs. Also, they really open up on a pole. ???.
Properly EQ'd, the Eminence kicked. What really impressed me was the mid-bass. The impact sounds of a kick drum. The snare. It sounded like a stinkin' AC-DC concert. I could more than feel the snare, I could taste it.
Anyway, I would go with a flexible, modular approach.
  #5
Old 11-28-2011, 09:23 PM
nashvillebill nashvillebill is offline
AK Member
The big question, to me at least:
What are your woodworking abilities?
What tools do you have and how much knowledge do you have of joinery? If all you have is a handheld circular saw, and have never built anything that requires more than nailing two boards together, then building a good set of speakers (PA or otherwise) may not be cost effective.
Shucks, even though I have a decent workshop downstairs, I'm not sure building PA speakers is cost effective. Carpet, glue, wood, corners, feet, handles, etc all add up....
And folks like this have empty cabs for $50. http://www.cheaplights.com/cart/page80.html
Of course, building something tailor-made may trump the cheap-price approach.
__________________
Bill
Audiokarma
  #6
Old 11-28-2011, 11:00 PM
mortron mortron is offline
AK Member
There was a lot of good things I have read about Bill Fitzmaurice designs and he offers some interesting and efficient designs which can be had for relatively cheap if you can find drivers at a good price. I don't know what kind of frequency response you end up with, but big SPL seems to be the flavor.
www.billfitzmaurice.com
  #7
Old 11-29-2011, 06:35 AM
westend's Avatar
westend westend is offline
Audiopile
All good suggestions above. I find that a horn based bin delivers a more disperse, involving sound than a straight cabinet. A compression driver with waveguide or horn mates well with the bass bin. This is basically what has been used in sound reinforcement for larger venues. You can also accomplish this at lower power levels if efficient drivers are used.
If Gordon has some of those custom reconed woofers available, that is probably going to be a good choice and you can decide on a cabinet based on those. I would suggest you seriously consider subscribing to AK and looking through the Bartertown section, too. The $25 subscription price would be offset many times over by the deals that are offered there, should you find what you're looking for (and you will).
  #8
Old 11-29-2011, 07:47 AM
whoaru99 whoaru99 is offline
Part-time Iconoclast
I've considered some of those, but some/many of the designs seem to require moderate to high degree of woodworking capability. If you need to have someone else make the cabinets I think the relativity of good price goes out the window.
  #9
Old 11-29-2011, 08:04 AM
bowtie427ss's Avatar
bowtie427ss bowtie427ss is offline
Don't Fear the Button
If it's any consolation, i'd wager that you have more than adequate patience and common sense to get thru any of BFM's designs with complete success.
If you can cut panels to precise dimension, some with 1 or 2 cuts on a mitre, then you're 90% of the way there.
If i can do it, you can too.
  #10
Old 11-29-2011, 05:39 PM
AK Member
Many of Bills designs require only straight edge cuts, and I think you even get plans to make a jig to aid the cutting, if you don't have a table saw. The Omni look simpler, as does the SLA.
Audiokarma
  #11
Old 11-29-2011, 05:50 PM
AK Member
  #12
Old 11-29-2011, 06:11 PM
petehall347's Avatar
petehall347 petehall347 is offline
the brandy coffee man
scoops are a well proven design for p.a cabs as are y bins ..if your amps can take a capacitive load maybe stick some large caps in the bins to give you good bass ? next thing would be an active crossover/ crossovers .. then some mids and tops ...3 decent amps and your away .. you could also put everything in the same boxes and use one amp or tri wire them .. i dunno there's a few ways to do it
  #13
Old 12-11-2011, 12:43 PM
AK Member
Thanks for the ideas everyone!
I do have some decent woodworking skills and have just about every tool available other than a bandsaw, so I should have no problem with that.
What if I rebuilt my DX-5's? The cabinets are already messed up so building new ones would help, and in the process I could upgrade certain components like the tweeter to an ewave. Is this a good idea?
__________________
Brad
  #14
Old 12-13-2011, 04:06 PM
drtechno drtechno is offline
AK Member
a 402 amp is not that much power, as I use the equivalent macro-tech on P.A horns.
I would use an xls 5000 (just to make the rack look more pretty, because a macro-tech 3600 usually alot more $$$) on a pair of subs like evx 180A's in bass reflex sub boxes.
and use a modest dbx analog crossover.
  #15
Old 12-13-2011, 05:54 PM
I'm guessing $1,000 in just sub drivers alone isn't in the picture, but maybe??
Stating the budget is always a good idea when asking for recommendations.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Meistertech Solutions
Capacitor World
AudioFriends
Analog Engineering Associates
Vintage Home Audio
Okki Nokki
Hudson Valley Hi Fi
Wargos Electronics
Organ Donor Parts
Parts Connexion
Sound Stage Direct
Take Five Audio
Audience AV
Howard Products
Simply Speakers
The Tube Store
FM DX Antenna
AudioClassics
Many Moons Audio
Audio Doctor
RSL Speakers
Yesterday's Audio
DeWick Repairs
BOI Audio Works
Politicalchat.org
MCM Electronics
Amplifiedparts
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
©Copyright 2002-2015 AudioKarma.org, All rights reserved.
