I got your inner grooves right here
Bob_in_OKC
Addicted Member
In light of Brett's comparison of inner grooves vs. outer grooves (I couldn't pick which was which), I offer the following. It's a minute or so from the 1st track on side one, the last track on side one, the 1st track on side two and the last track on side two...arranged in an order to challenge.
http://dl.dropbox.com/u/2951765/audio test (1).mp3
Edit: Here's a WAV version, but my prehistoric computer seems to be hiccuping and spitting a little...
http://dl.dropbox.com/u/2951765/audio test (1).wav
Although I have the advantage of knowing which is which, I do think there's a difference.
Hiya Bob, thank you for this!
I will try this again:
1-Outer
2-Inner
3-Inner
4-Outer
Pretty sure about the first 2 but not the second. But then again I don't know exactly what to listen for.
This being in mp3 form really makes it more difficult. Harmonic distortion absolutely disappears on low bitrate mp3's. Even when I recorded some records for a friend (uncompressed) on my Philips CD recorder, I noticed a huge difference monitoring the record's playback through the CD recorder's headphone jack, and playing back the CD I recorded moments before. So much information was missing! Harmonics, detail, tone- all altered! So much for "CD quality!" But I digress...
My guess is:
1. outer
2. inner
3. outer
4. inner
Though, odd that I hear more sibilance mistracking in the selections which I labeled "outer." :scratch2:
My guess would be: inner/outer/outer/inner.
But if the clips are close in character it´s mostly guesswork, we should be able to hear them switching place on the record.
gusten
To me they all sounded great - I did catch a faint bit of slight distortion on the very last one at the very beginning - just at the beginning.
Ok, my guess from a quick listen on plastic computer speakers:
Out
Out
In
In
But it all sounded quite good. Nice choice of music too.
This is fun!
:thmbsp:
This is fun!
:thmbsp:
Agreed!
As a matter of fact, I'm surprised there aren't more participants...
Bob... I went back and listened to the wav file, and the quality is considerably better. However it does get choppy and chattery towards the end, since it's such a HUGE file. Perhaps future needle drops with a higher bitrate mp3 (320kbps) would be a reasonable compromise between quality and file size?
Thanks so much for taking the time to share these samples!
Agreed!
I too think this stuff is fun. I do need to make a change on the file size and processing. I have a more-current computer I can move to. The 320k idea sounds like a possibility. In hindsight, I think Windows might have been downloading updates while I was recording, so I might try again with the network cable disconnected. I could see spots in Audacity where the recording was stopping and decided to just live with it for the test.
