Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Turntables
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 12-07-2011, 12:00 AM
kpsingh0 kpsingh0 is offline
AK Member
Turntable?
Hi looking to get a turntable to get into analog sound. I don't want too sped too much though would love to get pro-ject debut or essentials down the road. But to start of I'm thing vintage. I have track it to several I like
1. akai ap b20 $50
2. Harmon kardon T40 $120
3. Dual cs 505-2 $100
Do those prices seem fair. What table would you recommend. Any other recommends would be great. The hk is a bit out of what I want to send. Oh and how do the stack up against the pro-jects?
Thanks
  #2
Old 12-07-2011, 12:12 AM
Balifly's Avatar
Balifly Balifly is offline
Listening
Welcome to the turn table forum.
The Akai AP-B20 may be a good starting point.
Does it come with a function cartridge?
Here is a link to the owner's manual over at the Vinylengine library.
It is a free download after registration.
http://www.vinylengine.com/library/akai/ap-b20.shtml
You can look up the other two turn tables there as well.
__________________
Yamaha CR 2020---Luxman L-430
Sansui XP-99---------Luxman L-430
KEF 104ab---------Luxman PD-277
Stax SR-40--------Yamaha NS 690-----NS 70T
  #3
Old 12-07-2011, 12:26 AM
AK Member
Thanks for resource but I'm not sure what to look for.
  #4
Old 12-07-2011, 12:33 AM
Balifly's Avatar
Listening
What features would you like to have in a turntable?
Would you like a manual, automatic, semi-automatic type of turntable?
The description of the turn table in the library would tell you what type it is.
__________________
  #5
Old 12-07-2011, 12:49 AM
AK Member
I think I'd prefer a manual. but I'm not quite sure on the difference.
Audiokarma
  #6
Old 12-07-2011, 12:58 AM
Sam Cogley's Avatar
Sam Cogley Sam Cogley is offline
Last of the Time Lords
The H/K is a very nice deck.
__________________
Growing up leads to growing old and then to dying,
And dying to me dont sound like all that much fun...
-John Mellencamp
Burn the land and boil the sea...you can't take the sky from me.
-Joss Whedon
  #7
Old 12-07-2011, 01:04 AM
Balifly's Avatar
Listening
The Akai is an automatic, the Pro-ject is a manual.
http://www.vinylengine.com/library/pro-ject.shtml
Read the descriptions of the turn tables and then ask as many specific questions as you like!
Best of luck in your research!
__________________
  #8
Old 12-07-2011, 01:07 AM
dlaloum dlaloum is offline
AK Member
The Akai is an S-arm mid-mass arm table, The Harman Kardon T40 is a straight low mass arm, as is the Dual. All are belt drive, the Harman is from the best period of Harman turntables....
My guess is the Harman is the best TT of the three.
They are very similar in technology, market segment, etc...
Really depends on your intentions, and your budget.
Do you have any idea of what type of cartridges you would want to try on your table?
If you are interested in MC cartridges (which are mostly lower compliance) then the Akai has the edge, as the heavier arm will match better.
If you are interested in MM high compliance cartridges, then the HK and Dual are better due to the low mass arms.
Budget MC cartridges of note: Denon Dl103, Benz Ace, Dynavector DV10x5
For an MC based setup, you will also need a phono stage that properly supports MC's (higher gain, appropriate loading)
MM/MI catridges - these are mostly high compliance with a couple of exceptions... examples: Shure V15, M97xE, Ortofon OM & 2M Series, Grado (any), Audio Technica AT120/440/150, Stanton 680 & 880 series, Pickering XV15 & XUV/XSV series etc...
Low compliance MM's that would suit the Akai would include: Audio Technica AT95, Ortofon Omega, most Nagaoka's
Many of the MM cartridges can be upgraded by ugrading the stylus fitted - if the turntables come with a cartridge already fitted, you might decide partly based on the fitted cartridge (if something really nice and suitable is already fitted, then for the price of the stylus you would have an excellent setup)
more food for thought?
Bye for now
David
  #9
Old 12-07-2011, 02:31 AM
Van_Isle's Avatar
Van_Isle Van_Isle is offline
AK Member
Question on that Dual ... does it use the proprietary cartridge mounting system? I know the 'CS' stands for 'Complete System' that I thought means it uses an Ortofon cartridge custom made for Dual and hence hard to convert to a regular mount. If so that probably would be a significant consideration for the OP.
kpsingh0, you should find out, if you can, what cartridges come on each of these tables. There might be a real gem there that sways your decision.
Also does the T40 have the record weight with it (HK calls it a 'disk stabilizer')?
__________________
  #10
Old 12-07-2011, 09:03 AM
kermit z's Avatar
kermit z kermit z is offline
How Much Gear Do U Need?!
The differences in manual, Semi auto and auto are as they sound. A manual table you have to cue up the arm and lower it onto the record to play. Then at the end you will need to raise it up and place it back on the tonearm stand. A semi auto, you will need to cue the arm onto the record, but at the end, it will raise itself off and lower itself back onto the tonearm stand. The auto table will do all this by pressing a button. So, if you fall asleep listening to records or are doing other things around the house, then a semi auto will be good. Full autos are nice (My fiance loves it as its less scary ) because you don't have to do much. Manual tables are usually prefered by audiophiles as these are your basic tables with litle to go wrong. Project and Rega tables are all manual as far as I know. Thorens has some auto tables.
__________________
Main system- Yamaha M-70/Vincent SA-31-PHO-111/Sansui TU-717/TEAC A-3300SX/Marantz CD5004/Technics SL1300MK2 w Denon DL-160/Boston Acoustic A400/Dahlquist DQM-3
Living Room-YamahaM-50/KenBasicC1/Nakamichi 480/Kyocera DA610/Akai GX-265D/Pro-Ject RM1.3/Polk Monitor 10B
Audiokarma
  #11
Old 12-07-2011, 09:33 AM
parman's Avatar
parman parman is online now
Vinyl Addiction
Quote:
If you don't get a semi-auto you'll kick yourself.
__________________
I Like The Gear But It's Really About The Music
  #12
Old 12-07-2011, 10:53 AM
AK Member
I like the idea of a manual it seems more my style. maybe semi at the most.
-The hk has the original Ortofon cartridge
-The Dual also a Ortofon
-not sure on the akai, i stopped getting responses from this guy. Too bad casue i was leaning towards it. loved the price.
  #13
Old 12-07-2011, 11:12 AM
boreas's Avatar
boreas boreas is offline
AK Member
You could look for a Technics SL-1700 Mk2. It's semi-auto with the ability to operate as a manual, essentially a suspended SL-1200Mk2 with semi-auto capability and without the premium price.
John
__________________
Addictive Personality
C:\JB Graphics\Multi-Logo4xs.jpg
  #14
Old 12-07-2011, 12:30 PM
Dr Tinear's Avatar
Dr Tinear Dr Tinear is offline
AK Subscriber
Quote:
John
The original (Mk1) version of the SL-1700 is also worthy. The differences between the Mk1 and Mk2 versions are FG servo direct drive on the Mk1 vs. quartz lock on the Mk2 and a tonearm with a height adjustment on the Mk2 that allows the user to tweak VTA more easily. The Mk1 also didn't have the cueing belt issue that's common on the Mk2, which can be a bit messy or inconvenient to repair.
__________________
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
  #15
Old 12-07-2011, 12:59 PM
boreas's Avatar
AK Member
Quote:
A very worthy turntable!
That's literally a 5 minute & 75 cent fix. Maybe 10 minutes if you have a lot of belt goo to deal with.
John
__________________
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Hudson Valley Hi Fi
Okki Nokki
Organ Donor Parts
Capacitor World
Parts Connexion
Vintage Home Audio
Take Five Audio
Wargos Electronics
Audience AV
Sonneteer
Simply Speakers
Sound Stage Direct
Howard Products
AudioClassics
FM DX Antenna
The Tube Store
Many Moons Audio
Musical Paradise
Yesterday's Audio
McIntosh Cabinets
DeWick Repairs
BOI Audio Works
Politicalchat.org
Amplifiedparts
Audio Doctor
RSL Speakers
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
