Audiokarma.org
Audiokarma Featured Sponsor
Audiokarma will be offline March 7th and 8th
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Speakers
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 12-15-2011, 03:19 PM
dbxdx5 dbxdx5 is online now
AK Member
Dahlquist DQ-8 or Alon II?
I currently own the DQ-8s and love them! In fact, I bought them new when I was 17, so that means I've been using them more or less continuously for 24 years.
But... a friend is selling a pair of Alon IIs (re-foamed), and I'm considering taking the plunge, given that these, like the DQ-8s, were designed by Carl Marchisotto and share certain things in common, such as the open baffle and phased array. Has anyone here heard both speakers and able to give me their thoughts on which they liked best and why? I use a B&K ST-120 amp (the later version) with basic grey and black Kimber cable bi-wired to the DQ-8s.
Matt
  #2
Old 12-15-2011, 03:24 PM
stereocuuple's Avatar
stereocuuple stereocuuple is offline
Two Channel Only
i have owned both and now have alon IVs. do it you wont be sorry. also i have auditioned a B&K st 2140 with the alon IVs and it drove them with ease and was very musicial. the dq 8s are great but the improvement is massive with the alons.
__________________
"Maintain low tones"
  #3
Old 12-15-2011, 08:48 PM
Susurus's Avatar
Susurus Susurus is offline
Resolution:6.62×10^-34
Alon II is more ambitious. 3 way, heavier, larger, more bass. Closer to that price class would be 3-way DQ-20s.
  #4
Old 12-15-2011, 11:20 PM
AK Member
Quote:
I guess I'll interpret this to mean you think the Alon IIs would be a significant improvement over the DQ-8s (I don't own DQ-20s).
  #5
Old 12-16-2011, 10:41 AM
AK Member
Bump for any additional feedback. I plan to listen to the Alons tomorrow, so that will certainly help in my decision.
Audiokarma
  #6
Old 12-16-2011, 10:38 PM
Susurus's Avatar
Never heard Alons yet but I really like my similar DQ-20s. Both sets...
JD and CM understood how to make a great midrange work.
I like the DQ-8 but the DQs with 3 or 5 drivers are significantly better than the 2 ways.
  #7
Old 12-19-2011, 11:43 PM
AK Member
Thanks Stereocuuple and Susurus. I went ahead and bought the Alon IIs. Wow, these are revealing speakers! To this point I've only been able to listen to them with CDs (both of my turntables are out of order), so I'm wondering if the bit of stridency I'm hearing on some vocals are the speakers, the CDs, or my amp. The amp question is a concern because I'm using a B&K ST-140. It's the last version of this amp, which apparently some people say isn't good for driving 4 ohm loads (which is what the Alons are) and others say can handle 4 ohms fine. Stereocuuple: Is this the amp you drove the Alon IVs with, and is that a 4 ohm speaker? My hunch is that the stridency is the Alons laying bare the quality of some of the CDs for better or worse, whereas my DQ-8s softened things.
  #8
Old 12-20-2011, 12:51 AM
tubed's Avatar
tubed tubed is offline
AK Member
I found the floorstanding DQ-8 to be a very engaging speaker and so far, my favorite vintage 8" 2-way , more exciting to listen to than my Spendor SP-1s.
  #9
Old 12-20-2011, 03:02 PM
thedelihaus's Avatar
thedelihaus thedelihaus is offline
See me,touch me,Thiel me
The B&K St-140 is far from a strident amp.
I currently run B&K EX-442/EX-442 Sonatas, after owning some B&K ST-202 and 202+ models, all which are far from being anything close to strident.
The 202s will give you deeper, and more controlled bass. The EX-442s will give you more detail. But none will be strident.
What's your pre-amp? Your CD player? Your DAC, if you have one?
__________________
What you got back home, little sister, to play your fuzzy warbles on? I bet you got, say, pitiful, portable picnic players. Come with uncle and hear all proper! Hear angels' trumpets and devils' trombones. You are invited!
  #10
Old 12-20-2011, 04:05 PM
Mortsnets's Avatar
Mortsnets Mortsnets is offline
AK Member
The later version of the ST-140 (105w) with blue and red lettering can drive 4 ohm loads ok. Check your upstream components even speaker wire and cable.
How do the Alon's compare to headphone sound?
When I got new speakers limitations in other components were really called to my attention especially cd players.
Audiokarma
  #11
Old 12-20-2011, 08:47 PM
AK Member
Now I'm really thinking that the stridency I heard on a few discs is just the Alons revealing what's been there all the time: some not so great recordings or remasters. Anyway, here's my set-up:
Amp: B&K ST-140 (later 105 watt version)
Preamp: Anthem TLP-1
Digital sources: Denon DVD 3910 (no separate DAC)
Turntables: Beogram 8002 with MMC2 and a Perpetuum Ebner 2020 (idler drive) with Shure M97xe and Jico SAS
Reel to reel: Otari MX-5050 BII
Speaker Wires: Basic grey and black Kimber biwired to the Alons
Interconnects: Various types of Monster
  #12
Old 12-20-2011, 08:52 PM
AK Member
Quote:
I want to believe that, but there's such a question mark about whether this is true. For example, I emailed the very nice folks at Eastern Elite Audio Video, who are former B&K employees, to find out their take on whether the red and blue lettering version of the ST-140 can drive 4 ohm loads, and this was the "answer":
The amplifier specs is what I need to go by as well. We tested similar B&K amplifiers at 4 and 8 ohms and I could not tell you to use the ST140 at 4 ohms. We had many customers tell us they used it at 4 ohms but you could try it at your own risk. Sorry I could not be more helpful.
So it sounds like "no" but with an asterisk that in real-world applications people have said "yes." Tell me I'm overthinking this and that I should just listen to the music and unless I hear any audible distortion from clipping, then things are fine.
  #13
Old 12-21-2011, 12:40 AM
Mortsnets's Avatar
AK Member
Maybe your supicions are correct, here is John Atkinson comparing the 70w to 105w versions:
The main change, however, is the raising of the voltage rails from ±49V to ±60V without any difference other than reducing the output-stage bias current from 160mA to 140mA. (B&K's John Beyer tells me that this change occurred in 1985.) This raises the specified clipping power into 8 ohms from 70W to 105W, but renders the amplifier much less suitable for driving speakers whose impedance drops much below 8 ohms (as do many speakers).
http://www.stereophile.com/content/b...-atkinson-1990
Personally I've used the 105w version with 4 ohm speakers with no problem.
I would try swapping out the Denon for another cdp. Where do you live? Maybe you can borrow from another AK'er.
Here is a quote regarding the Denon:
The Denon added a slight edginess to the voice and tonal balance from top to bottom didn't sound like it was in exactly the right proportion — almost as if tone controls were (subtly) engaged.
http://www.enjoythemusic.com/audioph...nondvd3910.htm
__________________
  #14
Old 12-21-2011, 01:29 AM
donberry donberry is offline
AK Member
I never look for speakers anymore, am very happy with what i have and don't see the need. That being said, if I came across a pair of Alon or a pair of DQ-20 or DQ-30 I would buy them - and I have never personally heard either but I have zero doubt I would like them.
I could have got a pair of DQ-8 - nice speakers but I want the bigger boys.
__________________
ML SL3 - "While some people may prefer a speaker that demands less from them, these speakers are designed for those who demand nothing less than the best from their speakers." Stereophile Review 1997
  #15
Old 12-21-2011, 09:13 AM
AK Member
I'll have to read the Stereophile piece. I can say that I listened to the Alons some more last night with better source material, and they sound incredible. So not sure the Denon is causing any problems; it was probably the first few CDs I played. My question now re the B&K is this: Would I notice if it were having any problems driving the Alons? In other words, if I don't hear any distortion, can I safely assume that speakers and amp are fine/not being damaged in any way? Sorry if this sounds like a stupid question, but this is new territory for me.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Okki Nokki
Capacitor World
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
The Tube Store
FM DX Antenna
Musical Paradise
Many Moons Audio
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Audio Doctor
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
©Copyright 2002-2014 AudioKarma.org, All rights reserved.
