donprice
Wound up workin' at a gas station....
Many months ago I sent GordonW a trashed JBL 2206 for a custom recone something like the "2236" frankenspeakers he worked up for another member. The goal was to drop the Fs and get more bottom end out of it and make it a budget-friendly high performance ewave woofer.
From WT3 testing...
Fs = 32.3 Hz
Qms = 7.138
Re = 5.5 ohms
Qes = 0.527
Zmax = 80 ohms
Qts = 0.491
Le = 1.83 mH
Graph # 1 - used the high efficiency (>95 dB) ewave HF section. Low pass is also standard ewave L2 = 1.5 mH and C2 = 12 uF. I added zobel (C = 15 uF R = 7.5 ohms) across the woofer for good measure. Not bad, but the woofer rolls off a little early.
Graph # 2 - being lazy, I tried running the woofer naked for full range testing. It looks to me like it rolls off reasonably smoothly. A little tweaking on the HF section and it might be possible to make it work with no LP at all. I don't know if that is a good idea but it is in the econo spirit.
All curves smoothed 1/6 octave, measured at ~40" between woofer and waveguide.
Photos and more details later...
From WT3 testing...
Fs = 32.3 Hz
Qms = 7.138
Re = 5.5 ohms
Qes = 0.527
Zmax = 80 ohms
Qts = 0.491
Le = 1.83 mH
