So... let's see how my scanner's OCR s/w does with "Sonny's" description of this hi-fi system
"When we divvied-up the writing chores for the catalog this year, I instantly knew which systems I wanted to write about. After being here several years, I've developed some pretty solid opinions. . . so I wanted the systems I felt most comfortable with.
First off, if you're really into music, and you've
got the money, you're nuts not to spend at least $500$600 on a complete music system. As far as I'm concerned you can't get "the real thing" for any less even if it does come from us. I don't get off on any Hi-Fi set unless it's at least capable of rattling walls
and holding together at the same time - even though I don't always listen loud. And as good as some of our cheaper systems are - they won't satisfy me. Now, on the other hand, I also tend to think that it's a waste
to spend much more than about $900 on a system, because then you're just stroking yourself with a bunch of sophisticated non-essentials and "purity" - so pure that most people can't even hear the difference. So, let's get down to the specifics of this system for $595 and the next system for $692 - both of which I figure to be the best overall values in this catalog.
"Starting off with the Pioneer's SX-650 AM/FM stereo receiver is the best move you can make. It pumps out more than enough power (over 35 watts RMS per channel) to make the efficient ETR-18's really come alive and with less-than-audible distortion (under 0.3%) across the entire range of human hearing. As you can see, it has classic, clean lines, and enough controls to tailor the sound to your taste. Unlike most huge companies, Pioneer turns out a whole line of primo equipment, and their quality control and attention to detail is exceptional. The stuff just never screws up and we sell more Pioneer receivers than any other brand. Even the FM section reeks with quality - just spin the dial and it sucks in and locks onto stations with good sensitivity and channel separation.
(to be continued...)
