Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Exclusively Sansui
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 01-10-2012, 10:29 AM
solex solex is offline
AK Member
Question Sansui G-7500 - Help
Hi All,
I'm new the forum and just picked up a Sansui G-7500 it needs a volume know but more importantly it has a blown power fuse.
I have read the threads here on this common problem but will need some hand holding. Unfortunately I did replace the fuse 7AMP/250V and turned on the receiver and on of the 4 transistor smoked (no flames) and it looked like one of the pots as well.
Please let me know where to go from here, I would really like to fix this myself as the receiver as a whole is in excellent physical condition.
Regards,
Dan
  #2
Old 01-10-2012, 06:55 PM
cademan's Avatar
cademan cademan is offline
AK Member
Welcome! Most of the time when a fuse blows, its due to a bad or shorted output transistor.
What is your level of expertise? Do you own a volt/ohm meter?
If you know how to check the output transistors, check them first, then the driver transistors.
If you can, give us pic so others may see or spot trouble areas to help you out.
  #3
Old 01-10-2012, 07:03 PM
petehall347's Avatar
petehall347 petehall347 is offline
the brandy coffee man
look up "dim bulb tester" .it will save the equipment your time and money ...
  #4
Old 01-10-2012, 09:02 PM
AK Member
Hi thank you all for the responses, I will look up the dim light-bulb tool.
I attached some images and did a quick diode check on the transistors that I had access to (the ones covered by the metal shield) and recorded that all but one passed the diode check.
I assume that I also have to check the output transistors as well, although I would like to take them out without having to unsolder a lot of wires.
Where else should I look? Although not terribly important are there any sources for a volume knob.
I'm excited to see if I can get this piece working.
  #5
Old 01-16-2012, 06:52 PM
AK Member
I have order a better soldering iron and an solder vacuum hopefully this week I will start puling the transistors and ordering new ones when I get them all out.
I also order a G-5500 knob, I measured my existing tuning knob and it appears to be identical.
Audiokarma
  #6
Old 01-16-2012, 07:14 PM
SSBN 618's Avatar
SSBN 618 SSBN 618 is offline
AK Member
If you need a G-7500 schemetic, let me know.
  #7
Old 01-16-2012, 07:19 PM
AK Member
Thanks I pulled them off the Internet, can't wait to dig in...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
AudioFriends
Capacitor World
Okki Nokki
Analog Engineering Associates
Vintage Home Audio
Organ Donor Parts
Hudson Valley Hi Fi
Wargos Electronics
Take Five Audio
Parts Connexion
Sound Stage Direct
Simply Speakers
Audience AV
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
