webdog2010
I have an SX-626 that I acquired a couple of years ago. It has slowly developed noise in the right channel. I tracked the problem down to the control amp. After a recap of the control and eq amps, the problem persisted. So I looked to the transistors, expecting Q3 to be the culprit. I swapped Q3 and Q4, no change. Swapped Q5 and Q6, the noise moved to the left channel. Q5 and Q6 are 2SC1344. The manual also shows 2SC1312 can be used. I've gone thru many of the posts here and have found this listed as a replacement: ksc1845 512-KSC1845EBU (from Mouser), but they appear to be unavailable. I've been researching and it looks like this may work: 512-BC184. I am not an expert when it comes to transistors and I could use a little guidance.
This is my first post here, but I've been reading thru this site for a couple of years now. I've never had to post a question before because I've always been able to find the answers here. The level of knowledge here is just unbelievable. I've acquired a handful of other vintage pieces over the past couple years and this is always my first stop when trying to evaluate a piece.
Even if I don't get an answer on this question, many thanks to everyone who has helped me over the past couple of years without knowing it. The assistance has been invaluable.
