I like these things, but getting the right one is key. Years ago I had seen the Watts Dust Bug on a friends TT and set out to get one for myself. What I wound up with a was a far-superior piece from Audio Technica. Sorry but this is the best pic I could find of one:
Just like the Watts piece, the AT did a very nice job of dealing with the dust that wound up on the record while it was playing, but it ate up the static, too; that was selling point for me. It isn't shown in that pic, but a grounding wire attached to one of the small set screws you can just about see in the base, and that was the selling point for me. Additionally, it was made from some sexy aluminum and just wasn't as flimsy overall as the Watts. It worked wonderfully for an astounding length of time. How I lost this piece after 35 years in my last move is anybody's guess, but I did and haven't been able to snag a replacement yet.
I eventually caved in and purchased that German anti-static arm shown in a preceding post, which does its job quite well, as far as the static is concerned, but it doesn't do anything at all for the errant dust that finds its way on the surface during playback. It's somewhat difficult to get the balance just right, it tracks too fast most of the time and, frankly, it's kind of "spindly". Clearly, I wanted a better, more durable solution that was more in line with what I had in the past.
Having seen one mentioned in some thread on this forum, I purchased a Bib Groove Kleen NOS on U-No-Wut-Bay and took a gamble on it. While it is clearly set up/designed to deal with the dust issue, it has no ground wire for dealing with static. Upon closer inspection, however, I noticed that the German anti-static base and the Bib base looked remarkably similar....
Here's a tip: The Bib material is, as it happens,
very conductive. While the bases are similar and not identical, the Bib support post will fit
just fine into the German piece's base (which in my case was already adhered to my TT). It turns out that if you use the German base
with the ground wire, along with the rest of the Bib hardware (support post and mechanism), you've got your dust and static problems on the run. True, you have to have purchased both to do this and the Bib brush is sable and not sexy CF, but it works. If you've got more time and patience (and probably sense) than I do, you could always attach a ground wire to the Bib base and get where you need to be.
I thought it turned out to be a pretty nifty solution. Of course, now that I've done all of this, someone is going to suddenly discover a long-lost case chock full of NOS Audio-Technica Dust Bugs and post them on e-bay for $50.00 a piece.
