1978_DREAMER
Help! I've started my recap on my 2285B and things are going OK.
I just ran into what may become a problem as I try to get advice later, my P200 tuner board does not match the schematic that I have printed out.
My serial number is U140158. If anyone has the one that matches this I'd really appreciate a copy. Here's some pics. Not being a tech I'm keeping track of board location for each component that I remove. I use double sided tape stuck to a heavy paper and then stick the component to the tape and mark the paper
I did find one resistor on the P800 power supply board that has a corroded lead, it tests OK but I'll replace it.
Thanks, Jerry
Thanks, Jerry
