Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Speakers
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 02-06-2012, 10:48 PM
Ken Boyd's Avatar
Ken Boyd Ken Boyd is offline
AK Member
Restoring a pair of Sansui SP L700 speakers.
I purchased a pair of Sansui SP L700 speakers from an eBay auction about a month ago, and was really excited to get them as they looked like they would be a very good sounding pair of speakers. When I got them and hooked them up, I was quite dissapointed with there sound, so I decieded to attemped to restore them and hopefully they will sound a lot better. They lacked bass IMO having twin 10 inch bass drivers and a single horn behind an acustical lens, I thougth they would be a nice change from my usual speaker by being an easy to driver with a smaller nice amp and pre amp, without the need for such a large expensive amp that my other speakers all require.
I will take a lot of pics and let everyone know what I think when done. I could only take two evenings of listening to them before I removed them from the system. Other than looking nice, and being built very well, they sounded very bad.
Sansui SP L 700 manufactored in 1976 cost 210,000 yens, or $2,303.00 per pair.
Pulled the two bass drivers out, I couldn't tell that one of them the foam had pulled off the bass cone, the foam surrounds on these, glue to the back of the cone rather than the front, thats good, I won't have to worry about any glue oozing out on the front of the cones when I refoam them, hope to find the right foams, that might be a bit harder.
Pulled all the bass drivers out, one where the foam has split off the back of the cone. All the baskets are cast, nice size magnets,
Bass tuned port made of wood goes along the bottom and then turns up the back, all the sound deading material is fasten to the sides
Crossover looks pretty simple for a recap, looks like only two caps pre pretty decent sized ones. couple of resistors, and some inductors.
__________________
Vintage Infinity's, Phase Linear, Mcintosh, Sansui, SAE, Yamaha, Empire, Fisher, JBL.
  #2
Old 02-07-2012, 07:26 AM
cubdog's Avatar
cubdog cubdog is offline
banging through drywall
Good luck with your project Ken.
cubdog
__________________
Shuguang Classic S8MK
Bel Canto DAC 1.5
Squeezebox Touch
Sony SS-M7
Mirage BPS-150
  #3
Old 02-07-2012, 09:00 AM
Ricky1's Avatar
Ricky1 Ricky1 is offline
Lit by beacon fire
Wow, that's some pretty awful tearing on the foams. Hope this works out, I'm excited for it!
  #4
Old 02-07-2012, 09:22 AM
dc270's Avatar
dc270 dc270 is offline
AK Member
Little wonder they sounded poorly- the foams are pretty well gone! I bet they have large potential to sound good though!! I will be following- nevr knew Sansui made such nice, well made speakers!!
DC
__________________
DBX DX5 CD, Custom Morel 3 way speakers. Acurus DIA 100 int. amp, AudioSource 4 amp, Toshiba C15B pre, Luxman T-88V Tuna, Proton AP1000, SAE Two T14, Technics SE A7
  #5
Old 02-07-2012, 09:31 AM
ZeroJunk's Avatar
ZeroJunk ZeroJunk is offline
AK Member
After listening to big Infinitys I have found it difficult to find anything else that sounds good to me.
Audiokarma
  #6
Old 02-07-2012, 09:51 AM
jmosher's Avatar
jmosher jmosher is offline
AK Member
Looks interesting Ken. I will stay tuned.
__________________
Marantz 2216/2220B/2245/2252/ Pioneer PL-530
  #7
Old 02-07-2012, 10:40 AM
Ken Boyd's Avatar
AK Member
I have never rebuilt a crossover before, and since this one looks pretty easy I jumped in to give it a shot. Question for the AK members, do I need to worry about those two white resistors, and those two coils, I think they are called inductors. Do they need to be replaced or just the two caps?
__________________
  #8
Old 02-07-2012, 10:42 AM
Ken Boyd's Avatar
AK Member
Quote:
I think I am finding that out, but these should sound better than what they did, the foam for sure was a problem, but I have a hard time beleiving that these speakers shouldn't sound pretty good if everything is up to spec, am I wrong?
I personally have not be very inclined to own Sansui speakers but these looked like a different breed from the majority of ones I have seen.
__________________
  #9
Old 02-07-2012, 10:51 AM
dc270's Avatar
AK Member
These are certainly a fresh departure from the Kabuki types that many of the over sea products were known for being- they should sound really nice!
The resistors and inductors should be fine as they are. get you some nice Dayton 5% tolerance poly caps from PE and you are in business again!
DC
__________________
  #10
Old 02-07-2012, 01:47 PM
kermit z's Avatar
kermit z kermit z is online now
Loud Music saves Lives!!
Those sure do look nice. Once your done, let us know how they sound
__________________
Main system- Yamaha M-70/Vincent SA-31-PHO-111/Sansui TU-717/TEAC A-3300SX/Marantz CD5004/Micro Seiki BL-21 w/Denon DL103 SAJelco750D/Boston Acoustic A400
Living Room-Onkyo M-501/KenBasicC1/Nakamichi 480/SonyCDP-CA70ES/Akai GX-265D/Pro-Ject RM1.3/Polk Monitor 10B
Audiokarma
  #11
Old 02-09-2012, 06:25 PM
Ken Boyd's Avatar
AK Member
Ok today I removed the horn driver behind the accustical lens, unit states 7 ohms, the bass drivers have are marked 13 ohms. The horn is pretty heavy for its size.
Removed Horn driver
Here is a pic of the crossover removed
__________________
  #12
Old 02-09-2012, 07:22 PM
Ken Boyd's Avatar
AK Member
Well I have the crossovers out and it contains only two caps, they are located inside the aluminum cover which has an epoxy around them which is pretty hard to remove but on the cover it states, 125 WVAC 5.6 UF so I guess thats the value of the cap inside the cover. I checked out parts express and found about 6 or 7 different manufactors for them, ranging from price of about 40 dollars each to 3 dollars each. The Solans are $4.23, Kimber Cap $23.50, Janzten $4.18, Dayton $2.13, Auricap 6.0uF 400V Capacitor $25.45, Audiocap PPT Theta 6.0uF 200V Film/Foil Capacitor $37.47, a large price range of caps.
So what would be the real world difference. I need four, and I don't know how much of a difference the expensive ones will be over the cheap ones. I had a fellow AK member who has the same speakers use the Janzten he stated his speakers sound great, but I have found a lot of people claim great sound, from speakers that I personally would not consider great no matter what you did to them in keeping that in prespective, and the fact, these speakers might not sound good no matter what I do, is the more expensive caps worth the extra money. On the other side of the coin I don't want to put a cheap cap in and then think the speakers sound bad and not realise it was because of the cheap caps. The Jenzten ones he used were non polorized I take it that it would not matter which direction you solder them in, is that good or would a polorized one be better?
Any input on this would be helpful as I have never done this before.
Also one of those ceramic resistors the top seems to come off, and you can see a wire winding in the ceramic, is the top suppose to come off, the top cover is made out of the same material as the bottom with you can see a little bit of the wire coil embedded in the ceramic. It has 12 Ohm K on the side of it about 2 inches long.
__________________
  #13
Old 02-09-2012, 07:29 PM
Tom Brennan's Avatar
Tom Brennan Tom Brennan is online now
AK Member
You could be, that a speaker is well made is no guarantee it will sound good, indeed many very bad sounding speakers (IMO) were very well made. No doubt everyone here can give examples of well made speakers they despise.
  #14
Old 02-09-2012, 08:02 PM
avguytx's Avatar
avguytx avguytx is offline
AK Member
Personally, I avoid Parts Express like the plague when at all possible. Madisound has the 5.6uf Solen caps for $3.50 each and the ClarityCap PX series 5.6uf caps for $5.85 each. Those 2 are my picks above all else for the money and what I used (the Solens) on most all of my speakers. There are better caps, yes, but you do pay for them. Just my $.02 of course.
__________________
Carver C-1 BillD mods w/remote - M-1.0t Opt 002 - DTL-200 CD - JRiver Music Server FLAC files - Klipsch CF-3 (main system)
  #15
Old 02-09-2012, 08:28 PM
Ken Boyd's Avatar
AK Member
What kind of audio difference would I be able to notice? Would having the more expensive caps make a night and day difference, or just a slight difference and what would the difference be?
__________________
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Meistertech Solutions
Capacitor World
AudioFriends
Analog Engineering Associates
Vintage Home Audio
Okki Nokki
Hudson Valley Hi Fi
Wargos Electronics
Organ Donor Parts
Parts Connexion
Sound Stage Direct
Take Five Audio
Audience AV
Howard Products
Simply Speakers
The Tube Store
FM DX Antenna
AudioClassics
Many Moons Audio
Audio Doctor
RSL Speakers
Yesterday's Audio
DeWick Repairs
BOI Audio Works
Politicalchat.org
MCM Electronics
Amplifiedparts
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
