onepixel
I know this topic has been covered a number of times, and I've read quite a bit on the topic. But I'm not sure my methodology is optimal or if I'm just splitting hairs.
In the past I would rip rare albums that weren't available in any other format. I used my older Apple Power Book, Sansui SR-838, iMic and Audacity. Seemed to work easy enough and the filters would easily remove noise. The sound quality was good enough for mp3s.
The last couple days I've gotten serious about the whole setup/procedure. I'm now using a Apple MacBrook Pro, Pioneer PLC-590, Cary Audio tube pre-amp, Pro-Ject Phono Box II and the iMic. For software I started using Soundtrack Pro, which is an older version which doesn't have the click and pop filter so I bring the file into Adobe Soundbooth CS5 to remove the pops. But the noise reduction in Soundtrack Pro is fantastic. It lets you preview live, the music and noise separately while you make fine adjustments.
I experimented at capturing the music at various setting and what seems to be the standard. I tossed the files so these are approximations.
96/32 = I forget kbps, (AIFF-C, 200 MB)
96/24 = 6000 kbps, (AIFF-C,150 MB)
96/16 = 4000 kbps (AIFF-C,100 MB)
44/16 = 1536 kbps, CD Quality, (AIFF-C, 53 MB) Down sampled from 96/16.
Soundtrack Pro can capture at 196/32 which seems way overkill, so I didn't try it.
My ears can't tell the difference between these versions while using the Grado RS-2i headphones. These headphones are very revealing. I spent an excruciating time trying to reset-up the TT, because I noticed a little sibilance in the vocals. The song I used was Phoebe Snow's Poetry Man because I didn't have a digital copy and because the sound is clean and it covers a broad spectrum.
I think the 44/16 will work just fine for me, but am I missing anything? I'm asking because it takes me nearly 2 hours an album. Noise reduction is relatively quick, but taking out individual pops/clicks is time consuming.
Btw, the results are excellent. I'm going to have to A/B test ripped vinyl, 200 gm vinyl and CD.
Thanks!
Carl
Thanks!
Carl
