Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > The Cutting Edge
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 02-29-2012, 06:13 AM
YamahaFreak's Avatar
YamahaFreak YamahaFreak is offline
<-- CSXT 6038, EMD GP40-2
Question RCA Adapter Question
I am looking for a specific adapter to do a specific job, and Google searches are sketchy. I need an adapter that will take a stereo (2x RCA) cable and make it a mono (1x RCA) without removing either channel. A combiner, effectively. I basically need a way to run a stereo source into a mono amp/speaker without losing anything. If someone could point me in the direction of the cheapest way to do this, I would be most appreciative.
__________________
Ever notice that the peeled-off chocolate coating of a Swiss Cake Roll uncannily resembles bad surround flakes? :D
Ask me about my system! XD
  #2
Old 02-29-2012, 06:19 AM
petehall347's Avatar
petehall347 petehall347 is offline
the brandy coffee man
one of these should do it ..
rca splitter ..
or one of these ...
  #3
Old 02-29-2012, 06:50 AM
drknstrmyknight's Avatar
drknstrmyknight drknstrmyknight is offline
Frank
Search for Y cables
__________________
Living room: Squeezebox touch, Music Hall MMF5, Goldring 1042, MX110Z, McIntosh MC225, LaScalas
Mancave: Pioneer 510A, Ortofon Super OM 30,Shure M65 clone, Eico AF4, Fostex FE206E BLH's
  #4
Old 02-29-2012, 08:11 AM
Thank you!
petehall, were there supposed to be links in your post?
After browsing more of this board, I fear I may have posted in the wrong area.
__________________
  #5
Old 03-24-2012, 02:41 PM
ilusndweller's Avatar
ilusndweller ilusndweller is offline
AK Member
Is it this simple? I thought you needed some type of electronics or circuit to sum the L and R channel.
Audiokarma
  #6
Old 03-24-2012, 07:15 PM
Duckzilla's Avatar
Duckzilla Duckzilla is offline
"Laugh it up fuzzball"
Quote:
+2, thought a y-cable was to split one signal into two identical signals. You're not going to get a mono signal from hooking the left and right together, surely?
__________________
"And I thought they smelled bad.....on the outside".
  #7
Old 03-24-2012, 07:49 PM
BMWCCA's Avatar
BMWCCA BMWCCA is offline
AK Member
Quote:
I'd call that a short!
__________________
JBL, CROWN, SOUNDCRAFTSMEN, B&O, ASHLY, INFINITY, SAE, SHERWOOD, HARMAN/KARDON, NAKAMICHI, McINTOSH, APPLE, SONY, 6MOONS, RICK COBB, KENRICK, EMOTIVA, TEAC
  #8
Old 03-24-2012, 11:49 PM
Uncle Paul's Avatar
Uncle Paul Uncle Paul is offline
<--- VFET goodness
Not as bad as you might think, but not the best solution. If both outputs are from the same line level device they share a common ground, so usually the voltages will sum just fine and result in a mono signal. The output impedance, however, will be lower since both will be in parallel. Usually there will be a buffer following the sum to set the output impedance, but you won't get that out of a cable.
__________________
Zobel is as zobel does.
  #9
Old 04-19-2012, 03:29 PM
VinylRob's Avatar
VinylRob VinylRob is offline
Vinylphile
><((((º>`·.¸¸.·´¯`·.¸.·´¯`·...¸><((((º>`·.¸¸.·´¯ `· .¸.·´¯`·...¸><((((º>‏
In fact I read, Art Dudley recommended two Y adapters connected at the (combined) single end tail side to sum a Stereo feed to dual Mono feed as a cheap and simple way to enjoy Mono recordings on a Stereo system.
Happy Listening!
__________________
So much vinyl... and so little time.
To see a World in a Grain of Sand. And a Heaven in a Wild Flower, Hold Infinity in the palm of your hand and Eternity in an hour. William Blake
  #10
Old 07-11-2012, 04:35 AM
It may have been a good idea to elaborate on why I needed this done. x3
I have an old Webcor 4905 two-way amplified speaker (vacuum tube amp) and want to use it with stereo sources. It's got one 'LO' input and one 'HI' input, both a single mono RCA jack. I need to sum the two (stereo) RCA cables from my stereo sources into the single (mono) input on the amp, without losing anything. So far, I am using a generic 2-to-1 RCA adapter cable, and it seems right, but the sound is off a bit, and I just can't put my finger on why. Both channels DO seem to be there...
__________________
Audiokarma
  #11
Old 07-11-2012, 07:20 AM
stu49 stu49 is offline
AK Member
I made one using the lead from an old set of headphones. Worked perfectly for years feeding mono vcr into stereo amp.
Much easier to buy 2rca male -1 rca male. They are readily available.
cheers
Stu
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
AV Solutions
FM DX Antenna
Musical Paradise
Grant Fidelity
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Urban Antigue Radio
The Tube Store
Many Moons Audio
Audio Doctor
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
©Copyright 2002-2014 AudioKarma.org, All rights reserved.
